Just tried with version 00.03.01 and worked perfectly!
Now I've a "DS1102E" 100Mhz scope!
THANKS A LOT! I know this (03.01 hack) originated in a german forum, great work!
Just some things:
1) When updated to version 4, screen flicked sporadically. Would be unusable if stayed on that version.
2) When downgrade to 00.02.02.02.00 hardware version, serial number and model got lost! (not an issue, don't panic)
3) DSP version changed from 00.01 to 02.15 and FPGA went from 03.07 to 02.00. Not saying it's a problem, just reporting.
Finally I upgraded to 00.02.04.01.02 without a problem. Now showing model DS1102E, hardware version 58, dsp 02.20 and fpga 02.00.
I read some people saying to get back to version 4 after the hack, but I had some issues with the screen on that version. So won't try it again.
EDIT: Ok , I was able to downgrade to 2.02 SP2 but now i can't see the SN or the Model. Any Idea?
https://www.dropbox.com/s/7y0vyeb7pi7nqz9/20121128_021700.jpg
Hello,
no problem, the is serial number see backwards of DSO (SN DS1ED########),
you must write in demoIDN for conversion to 100Mhz DSO:
1. ":INFO:MODEL DS1102E"
2. ":INFO:SERIAL DS1EB########" '######### your serial number
3. ":INFO:HARDVERSION **" '** your Hardversion e.g. 58
or for conversion to 150Mhz
1. ":INFO:MODEL DS1152E-EDU"
2. ":INFO:SERIAL DS1EF########" '######### your serial number
for default DS1052e
1. ":INFO:MODEL DS1052E"
2. ":INFO:SERIAL DS1ED########" '######### your serial number
regards René
