I see the dedicated purpose of the unit, most things battery related. The
S/W is $845/year am I right?
For the dollars, I think it should be a free maga
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
PSU and load i.e. be able to emulate solar panels for MPPT testing. No hardware difference for the PSU. Why would you not have this instrument general purpose?
I can't find input or output capacitance spec for it because that affects the impedance relevant with batteries feeding boost/buck converters for example. If it's got a fair bit of added capacitance then your "low battery" emulator works better than the real thing.
Oh and the SMT heatsinks for the DPAKs, I tried using them in a design and they are not serviceable, impossible to desolder. A blow torch could do it but they are pretty much something needing reflow IMHO.
