I did know the Model 100 used AA, that's a lot of AA I guess!
While I like Li for power density, I'm not a fan of their erratic behavior if left unused or worse if fully discharged and stored, nor that it just ages and dies even if unused or violently explodes if charged improperly.
In my personal experience, I've seen some of Chinese no-name Li get unbearably hot and start deforming its casing for no apparent reason, it was fine when it was young.
NiMH can be stored as is and will stay relatively fresh if unused for years,
http://www.mrs.org/s_mrs/sec_subscribe.asp?CID=12302&DID=236622&action=detail... just cycle them to get them awake, and if improperly overcharged will just bubble out and die a graceful but user safe death.
I've had this happen to me 2x but not as severe, using again, no-name Chinese NiMH cells charged properly in a charger.
Old NiMH past its lifetime get senile in terms of mAh and just sleep permanently neither blowing up, overheating, nor holding a charge.
So, I'm not just a fan of NiMH, AA, and AAA for its ubiquity and ease of working with, but its safety and low cost. While the form factor leaves problems, an AA powered device from the 1990s likely will work today by just putting fresh cells into them, while a Li powered device will need a new battery or pack that may be difficult to find.
I have 2 computers that take AA batteries...
a Tandy TRS-80 Model 100 (maxed to 32k ram and has an assembler option rom installed) which According to Gates, "part of my nostalgia about this machine is this was the last machine where I wrote a very high percentage of the code in the product".
and an HP 200LX that has PC-GEOS installed on it. Both still work great
