Author Topic: EEVblog #946 - Apple (Raspberry) Pi Cluster - PART 2  (Read 31751 times)
Offline boz
    • Roving Dynamics Ltd
Re: EEVblog #946 - Apple (Raspberry) Pi Cluster - PART 2
« Reply #50 on: November 24, 2016, 06:10:56 pm »
1) can you power a rpi straight from the 3v3 gpio pin?
Yes, I have also done it on a few boards now (eg http://rodyne.com/?p=754) and it works real good, you can also provide a shutdown signal (and UPS) if needed through a GPIO
Fearless diver and computer genius
Offline bktemp
« Reply #51 on: November 24, 2016, 06:55:03 pm »
I think you mixed up 5V and 3.3V. Powering from 5V pin is possible, from 3.3V does not work, because the processor core voltage is supplied by a stepdown powered from the 5V rail.
Offline Nobody2
« Reply #52 on: November 26, 2016, 02:48:06 pm »
Hi Dave,
considering you would want the "minicomputers" (as a general term independent of the exact model you want to use) mount horizontally (for airflow), have you also considered to mount them rotated? Either by using the network and USB ports to plug into your board directly (USB for power, I don't think they have protection to prevent that) or so that USB and network remain accessible on the top. Doing so should increase the number of pis you can have in each row.
I don't think using the SPI-Ethernet bridge would be a problem in you case, because the the spi port is not that slow (megabit/s range) compared to an average internet connection, but having the network switch integrated on the board would be cool.
As for potential "daughter"-boards. I don't think there is a reason to connect through all 40 pins. Just power and the network connection should be sufficient. So even two to one, or three to one adapter boards should not require big connectors, although mechanical stability might be a major concern.
If you don't require easy access to the individual "minicomputers" later on, you also might want to consider to stack two mainboards on top of each other as a second layer, instead of using 20-30 2-to-1 adapters, in order to get a better "fill-factor" of the case.
The following users thanked this post: boz
Offline Artlav
  • Country: mon
    • Orbital Designs
« Reply #53 on: November 26, 2016, 05:30:17 pm »
As for airflow optimization for the Raspberry Pi,
Neat. What software was that made with?
Offline wesphillips
« Reply #54 on: November 27, 2016, 01:33:29 am »
I Agree with Tobia. This right angle connector would allow just such an option:
https://www.adafruit.com/product/2823
I just wanted to mention that there are several kinds of 90° header connectors especially designed to mount RPies vertically on a mainboard.
The Orange Pi has a 180° rotated header, but you just need to mount it upside down and the IO pins align perfectly.
Excuse the crudity of the ASCII art model:
|      |1 2|  2 1       |      |40 |     |      |2 1|  2 1
|      |3 4|  4 3       |      |. .|     |      |4 3|  4 3
|      |. .|  . .       |Orange|. .|     |Orange|. .|  . .
| RPi2 |. .|  . .       |  PI  |. .|     |  PI  |. .|  . .
| top  |. .|  . .       | top  |4 3|     |bottom|. .|  . .
|      | 40|  40        |      |2 1|     |      |40 |  40
|          |  main-      (no good)        (flipped)    main-
+----------+  board                                    board
              header                                   header
      |   right-                            right-  |Orange
  RPi2|   angle                             angle   |PI
      |   connector                         conn.   |
      |-1 ---+                               +--- 2-|
      |-2 -+ |                               | +- 1-|
           2 1     <- same mb layout! ->     2 1
    mainboard                                mainboard
Offline kc8apf
« Reply #55 on: November 28, 2016, 06:34:09 am »
I chuckled when I saw Dave pointing out the bodge on the G5 motherboard.  A good friend of mine who still works at Apple was responsible for that bodge.  There was a timing bug in the first production run of northbridge ASICs.  That wire is the proper length to insert the a delay to "fix" the bug.  Ah, memories of weeks spent in lab figuring that bug out.
The following users thanked this post: BillyD, thm_w, exuvo
Offline Doofenshmirtz
« Reply #56 on: November 29, 2016, 05:58:12 am »
Hi, Dave.
I know your focus tends to be hardware, but have you considered a more 'software' alternative to this project?  That is, something different than Ethernet to connect your boards?
Thinking being...
* You don't need high performance, you just need connectivity
* You've got a lot of header pins, SPI, etc to create a shared comms bus
* One Pi on the bus could act as a gateway to the rest of the world via its Ethernet (using NAT)
* The missing link would seem to be a network driver implemented on SPI (i.e., SPI between Pis, not to an Ethernet controller)
[Edit 1/7: I've learned that no SPI slave driver has been developed for the RPi, so you'd have to bit-bang your own bus+network driver using I/O pins.]
I'm on a similar quest, but I haven't yet gone hunting for such a driver, so I don't have a turnkey solution for you.  But boy, would it simplify the design - I've got to think someone has coded this by now.  You could practically use an IDC ribbon cable for the bus and some standoffs to stack the Pis.  (Or, for a PCB design, a right-angle female 2x20 header pairs nicely with an IDC shrouded pin header - no PCB slot required.  Cost for headers from Adafruit is cheaper than Digikey, at least for the US.)
The above would have a bonus of being a low-cost solution for Pi Zero, which might make it $/GHz more attractive.  If you could circumvent the need for an SD card (which would be a whole separate project), that practically cuts the Pi Zero cost in half.
Speaking of Zero, the new Orange Pi Zero looks pretty darned attractive at USD$7 with quad core 1.2GHz, 256MB RAM, and wireless.  All it'd need is a couple pins for power.  OS support seems sketchy out the gate, but I expect that'll resolve itself in due time.  If it works well, it seems like game-over for this kind of 'clustering' project.
And Pi Compute Module... has previously offered small form-factor, but higher cost.  Since the CM3 is claimed to be backward-compatible at the connector with CM1, I expect it to similarly be a subset of Pi3.  But it does have MMC instead of SD, which is nice.  It's handier for integrating into a commercial product, but if you can make a Pi3 work it'll probably be a cheaper 'Raspberry' option (i.e., if you ignore Orange).
Cheers,
Richard
« Last Edit: January 08, 2017, 02:33:44 am by Doofenshmirtz »
Offline jeff.moye
« Reply #57 on: November 29, 2016, 10:50:48 am »
Hi Dave,
Why not design your riser boards so that the Pi's all have their ethernet ports facing you?
(see attached JeffCad printout - had to find an envelope especially for this project!)
This will have he following advantages:
  • narrower footprint - should allow an extra column of pi's
  • ethernet cables won't obstruct airflow over the boards
  • usb ports are exposed - allowing usb drives or other devices to be connected
Jeff
Offline CaptCrash
« Reply #58 on: November 29, 2016, 11:39:13 am »
If the point of this is to process SETI@HOME or other things via BOINC, then the focus on the ethernet controllers seems to be a waste of time, Its not a component of the design that matters.
On the other hand making a sexy board design that the Pi's/OrangePi's can connect into would be great and from that point of view, maximising density, minimising parts counts (ethernet switches, cables, USB power etc) would be a great goal.  Especially with the use of SPI networking or similar, where the ethernet and wireless chips can be shutdown to save power and more importantly heat on each Pi.
I thought I would have a go with this as well (not the electronics part yet), with a bit more of a focus on the computing side for a bit of fun.  To start I went with the following
3 x raspberry pi 3 model B's running Raspbian Jessie Lite
3 x 8gb Micro SD cards
1 x USB high power hub
Other accessories to setup
HDMI to VGA adapter
Keyboard and monitor
I setup the three nodes, as rp3-0, rp3-1 and rp3-2, currently they all attach to my wireless network and directly collect work units from the internet, my next change is to run the rp3-0 as an access point with a seperate SSID and route the network data via this node to my cabled network.  The end result will be one ethernet connection with however many Pi's that I add as I go forward connected wirelessly, inside of a metal PC case with fans and a single power supply.
The network bandwidth that the PI's need is insignificant as they download a work unit, then process it for some time before uploading the result to the internet.  In my case, my ADSL has a download rate of approx. 3mbits/s so even the worst wireless network performance (11mbits/s) easily outpaces this.
On the other hand if you want to run actual cluster applications (not what has been mentioned in the video's, something like the video below), using MPI or an equivalent, then having a common file system (NFS or NAS share), better network performance etc would be important.
One item that I haven't really noticed you mention or focus on in the videos as yet is what you will do to assist with the cooling of the Pi's other than just some fans.  In my case I have stacked the three Pi's with 30mm risers between them and have a fan blowing across them.  I found that they were running at 60-70c when running 4 BOINC threads per Pi (it was about 26-28c in the room) after a couple of hours.  I then added some small heat sinks to the processor, dropping the processor temps to 50-52c.  note: Temps are from the systems software reported temps, not actual measurements.
Then I had a bit of a play with the overclocking parameters on the Pi's, increasing the CPU to 1.325GHz, increasing the memory bus speed to 450 and increasing the core voltage setting to 4.  This lifted the operating temps to 52-54c, but with an improvement of about 17% in the processing performance of the Einstein@Home work units across all three devices.
Im keenly following your progress.  I am also starting to have a play with MPI on the cluster to see if I can use it to do something useful with it, other than its current task of monitoring the temps on all nodes in the cluster.
« Last Edit: November 29, 2016, 11:44:41 am by CaptCrash »
The following users thanked this post: Doofenshmirtz
Offline boz
« Reply #59 on: November 30, 2016, 03:27:11 am »
Correct, too quick on the keyboard..
Offline richfiles
« Reply #60 on: December 02, 2016, 05:16:21 am »
http://hackaday.com/2016/12/01/running-intel-tbb-on-a-raspberry-pi/
I'm no expert in this stuff, but I'll just leave this link here, and let those who understand it decide if it's worth looking into. Basically, someone got Intel’s open source Threading Building Blocks running on the Raspberry Pi to "achieve better parallelism in his OpenCV project". Intel TBB wasn’t available in Raspbian, due to some kind of issue with creating a build to run on ARM, but this dude was able to create a working build, and made it available to download.
I don't know if it's relevant for this build, but I'll just leave that there for those interested.
As far as the build itself goes, I have to say i rather like the idea of using multi-level risers that mount at least 2 boards deep, and PCB "strips" that have the male RJ45 plugs acting as board to board interconnects. For airflow reasons, I see no reason that the Ethernet PCB strips need to be rectangular either. Routing the boards at follows:
[_]_[]_[]_[]_[]_[]_[]_[]
This would optimize airflow, since you only need boards as wide as the traces themselves need to be. You might even be able to optimize manufacturing by having two boards mirrored against one another, so the protrusions for each male RJ45 connector intermesh during manufacture, to minimize wasted board space. One would assume one end would be larger, so as to support the Ethernet switch chip, and an RJ45 connection to either an external Ethernet switch, or to another riser board, designed to bridge all the ethernet PCB strips to the motherboard.
____
btw... What the heck is up with this forum not supporting extended unicode characters... I had a GREAT diagram for that PCB made up from unicode, and it failed to post properly. Had to redo it in basic ASCII. What is this? forum software from 2002?  :palm:
« Last Edit: December 02, 2016, 05:21:44 am by richfiles »
Offline PODF
« Reply #61 on: December 15, 2016, 09:09:49 am »
Hey Dave
I will help you with the Linux side of this Project. Maybe i can write one or two bash scripts for you. Help setting up the software side. Just ask.
And thanks for your great videos!
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #62 on: December 17, 2016, 01:05:33 am »
RPF have relelased information on some new features in Pi 3 bootloader - mainly netboot is interesting here. This means you can set up the cluster to boot off a single Pi over network, without a mess of SD cards.
Offline johnkeates
« Reply #63 on: January 16, 2017, 05:10:34 pm »
Not sure how alive project is, but: https://www.raspberrypi.org/blog/compute-module-3-launch/
Makes for a much better modular cluster I'd say. Technically you could combine this with other form factors too, just make SO-DIMM carrier boards for them.
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #64 on: January 16, 2017, 06:25:28 pm »
I just came here to post that too. Stock seems limited though (Farnell UK prices):
Data sheet: http://www.farnell.com/datasheets/2175850.pdf
(Version with eMMC)  1+ £24.75 100+ £23.50
4,475 will be available for delivery on 05-Feb-2017
More stock available week commencing 24/04/17
(Without eMMC)  1+ £20.50 100+ £19.50
15 will be available for delivery on 20-Jan-2017
4,420 will be available for delivery on 05-Feb-2017
Dev kit £164
43 will be available for delivery on 20-Jan-2017
1,062 will be available for delivery on 05-Feb-2017
RS Components price: £26:99  £21:99  £125:99  (RS seem to have a lot more in stock at the time of checking)
Seems kinda expensive to me, maybe it is early adopter tax?
Offline thm_w
  • Non-expert
« Reply #65 on: January 16, 2017, 08:20:31 pm »
It was always going to be expensive as its expected to be used in commercial products. The Rpi/Rpi zero are subsidized so price is lower than expected.
Rpicompute 1 is available for a few pounds less.
Of course compared to orange pi etc. its a lot more. But I have yet to see a plug in module from them, they could easily design one and sell for half the price.
Offline KiwiDaz
« Reply #66 on: January 17, 2017, 12:27:03 am »
Now no connection issues Dave, standard SODIMM edition : http://tinyurl.com/haydble
« Last Edit: January 17, 2017, 12:29:04 am by KiwiDaz »
Offline Lux_
« Reply #67 on: January 30, 2017, 06:08:59 pm »
Does someone know if this project will be continued by Dave?
Lux,
Offline Lux_
« Reply #68 on: February 26, 2017, 07:41:54 pm »
nobody?
i really liked the project.
Offline stuckat1
« Reply #69 on: July 19, 2017, 03:37:58 pm »
Bueller?  Bueller?  Bueller?
Offline jack-daniels
« Reply #70 on: July 19, 2017, 06:15:27 pm »
You're still here? It's over. Go home.
The following users thanked this post: Fungus, kingsolmn
Offline kingsolmn
  • 220, 221 - whats the difference?!
    • TeamRampage Services
« Reply #71 on: August 15, 2019, 06:21:54 am »
Forgive me if it's a no-no to bump this thread, but I'd really like to hear if Dave's done any more with this. I'd really like to see the finished project as it sounds like it's going to be quite the sight when done.
I originally came across these videos about a year ago and got rolled by life ( :-//) and came over to have a look to see if there's something here about an update to the project, but alas no :-BROKE.
I run a small IT/Electronics repair shop out of my garage. The electronics part came about because my son was getting old enough to use a soldering station by himself and does some pretty interesting things (and he has plenty of ideas!) and e-waste recycling for parts (except for the eBay stuff).
