Author Topic: EEVblog 1426 - This Problem can DROP Solar Output by 20%  (Read 8469 times)
Offline Kleinstein
Re: EEVblog 1426 - This Problem can DROP Solar Output by 20%
« Reply #25 on: October 26, 2021, 10:23:43 am »
The orientation of the shade is in a way, that it does not take much to essentially turn off 2 whole modules. It only take a 2 cm wide shade horizontally across the module to essentially take that module out of operation. The problem is a bit in the way the cells are gouped for the bypass doide. That one is more suited for a vertical shadow coming  from the side and maybe shadow the left or right half.
