Can’t wait to see this one!
Hope you at least got some shots of the guts of the power amps and the HV power supply, since you didn’t take them with you.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
This is a GREAT subject for a teardown, as most electronics folks have never seen or worked with multi-kilowatt RF gear, or “modern” equipment that still uses vacuum tubes. Coax feedlines that look like copper pipes, water cooled dummy loads, all kinds of neat stuff at transmitter facilities, and it is always nice to look at gear that hasn't been built down to a price point, but designed to run 24/7 for years, often unattended.
