Author Topic: #186 SMD Soldering - Tips Used  (Read 10257 times)
Offline timdTopic starter
    • Tim's Random Crap
« on: August 05, 2011, 05:39:36 am »
G'day -
Is that well tip on the Hakko or the Pace? Which number is it?
Cheers.
    • Tim's Random Crap
Re: #186 SMD Soldering - Tips Used
« Reply #1 on: August 17, 2011, 02:33:36 am »
Does anyone know?
Cheers
Online IanB
« Reply #2 on: August 17, 2011, 02:39:25 am »
Does anyone know?
The Internet knows all. I'm sure if you searched the Hakko and Pace company web sites for replacement tips you would find what you seek.
Just as an FYI I've been there and done that with Hakko, and found "well tips are not available for Hakko irons in the USA". I assume there is some kind of patent issue surrounding them. My guess is that some other company has the monopoly on them.
Offline shadowless
    • Tim's Random Crap
« Reply #4 on: August 19, 2011, 10:36:34 pm »
Thanks guys I did take a look a the Hakko site but somehow missed it.  :-[
Offline alexh
    • Alex' Page
« Reply #5 on: September 10, 2011, 09:06:46 am »
Well, actually the CM/BCM tips (well-type) don't seem to be available for the FX-888 (T18 tips). They are available, however, for the FX-950 (T12/T15 tips). Bad news is that the T12/T15 tips are nothing like the T18 and wouldn't fit the FX-888.
Cheers,
Alex
« Last Edit: September 10, 2011, 12:01:32 pm by alexh »
Offline derjuden
« Reply #6 on: November 14, 2011, 04:47:45 pm »
I have been doing some searching my self for what type of tip Dave was using in this episode and I really don't think the well hakko types BCM are it.  When he puts it at the camera I believe you could see an actual hole in the tip, not just a concave surface.
Here are all the names that different solder iron companies use that could be what he is using that I could find doing some research online.  Again I dont think the BCM is what he is using.
bucket, flow, spoon, bevel with indent or Shape BCM/CM from Hakko.
Offline Randall W. Lott
« Reply #7 on: February 28, 2012, 02:35:49 am »
T18-D24 is a chisel tip with a 2.4mm diameter.  This looks like it could be it.
- Randy
Offline TerminalJack505
« Reply #8 on: February 28, 2012, 03:32:54 am »
Hello!  Hello!
Plato (r) SMD Flow Tip:
http://www.mouser.com/ProductDetail/Plato/HS-0530/?qs=yG55FOIierkI6FzqsFJXbA%3d%3d
Found that from here:
http://dangerousprototypes.com/2012/02/17/drag-soldering-tips-for-hakko-900m-series-and-compatibles/
They're not Hakko brand but--unlike the Hakko well tips for the 900Ms--they're available in the US and according to that dangerousprototypes article they're compatible.
Offline ToddFun
    • ToddFun.com
« Reply #9 on: March 03, 2012, 05:43:12 pm »
THANKS! I have been looking for these in the USA and just couldn't find anything.
I just ordered both of these:
http://www.mouser.com/ProductDetail/Plato/HS-0530/?qs=sGAEpiMZZMt%252biMJH3c40u3nmZTHA3oRdTHTMO%2f7Lfxo%3d
http://www.mouser.com/ProductDetail/Plato/HS-0531/?qs=sGAEpiMZZMt%252biMJH3c40u3nmZTHA3oRdpMQFW0QORKk%3d
Not sure if the 3mm or 5mm well will be best for my work but at $7 each I just got them both.
« Reply #10 on: March 03, 2012, 06:20:25 pm »
No problem.  I bought one of each as well and got them today.  They fit the Hakko just fine.  It's hard to say just yet but they seem to be good tips.  I put the smaller one on the iron and the tip had no problems wetting with some 60/40 rosin core solder.
I've never tried drag soldering before so I can't really say if they'll work good for that or not.
