Author Topic: $140K Agilent Oscilloscope Unboxing (EEVBlog 2)  (Read 4586 times)
Offline German_EETopic starter
« on: September 20, 2014, 01:50:24 pm »
One of the first posts on EEVBlog 2 was the unboxing of a very expensive oscilloscope:
What happened to this device because I do not recall any further mention? A review would be nice,a teardown would be even better  :)
Warren Buffett
Offline andtfoot
Re: $140K Agilent Oscilloscope Unboxing (EEVBlog 2)
« Reply #1 on: September 20, 2014, 02:43:45 pm »
There are a couple of spots where it's used here:
Then a bit of a teardown here:
« Reply #2 on: September 20, 2014, 09:17:30 pm »
The unboxing was posted three months ago but Episode 340 was in August 2012. Has Mr Jones invented time travel?
Warren Buffett
Offline baljemmett
« Reply #3 on: September 20, 2014, 09:44:40 pm »
I think the unboxing originally went up on the main channel, or possibly Altzone, when Dave received and played with the scope - the EEVblog 2 channel is much newer than that, so presumably he's moved a few older videos off the main channel to the secondary.
Offline EEVblog
« Reply #4 on: September 27, 2014, 12:57:54 pm »
It was posted on my personal altzone channel at the time.
