I've got a retro ZX Spectrum which has a power supply issue. From the posts I've read the circuit takes the +9V and 5V and has a DC-DC inverter circtuit to generate -5V, -12V and 12V (For the dram chips)
The problem I'm having is I get 12V and 5V but do not get any negative voltage.
A common issue is TR4 blowing which takes out TR5 as well. In my case TR4, base-emitter was shorted. I replaced TR4 and TR5, powered up and TR4 blew again. Its possible there is a faulty dram which is causing some issues on the -5V
I've checked shorts between -5 to gnd, and -12 to gnd. All fine there
First I would like to understand how the circuit works so I can figure out why there is no -12/-5.
From what I've read there should be a square wave on collector on TR5 which I'm not seeing. How exactly is this oscillation setup through the coil with TR4/TR5?
I've tested the resistors/caps/diodes, all working so can't think why its not oscillating.
Next to try and stop TR4 from blowing all the time I need to connect up my current limiting power supply and try and isolate it from supplying the rest of the PCB with -5/-12.
If I can to cut the track between C46 and C49 and remove D15 would that isolate the -12/+12V/-5V? Would this mess up the oscillator circut?
Attached is the DC-DC circuit
Full schematic here: DC-DC circuit at the bottom.
https://spectrumforeveryone.com/wp-content/uploads/2017/08/ZXSpectrumIssue3-Schematics.gif
