Also something about thermal equilibrium and carrier diffusion, being in the drift velocity regime.
I think that means mobility is effectively lower once you hit saturation velocity?
(Which is also kind of a quirk of GaAs, the electric field required to reach saturation is below that required for impact ionization (avalanche), whereas it's the other way around in silicon for example.)
Eh, it's been forever since I worked with these equations...
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
