Author Topic: Zener question  (Read 11476 times)
Offline tnadysTopic starter
Zener question
« on: April 07, 2014, 09:02:17 pm »
I have a piezo connected to a zener and am noticing that it seems to be scaling instead of clipping the signal. I prefer it to scale but this doesn't seem right, am I missing something? I am just using a piezo to try to learn about rectifiers, opamps, filters, comparators etc.
Tac Eht Xilef
  • Guest
Re: Zener question
« Reply #1 on: April 07, 2014, 09:24:08 pm »
I have a piezo connected to a zener ...
How?  :palm:
If you provide a schematic or circuit diagram we might be able to explain what's happening.
Offline Hideki
  • Country: no
Re: Zener question
« Reply #2 on: April 07, 2014, 09:39:59 pm »
Maybe you should add "How to explain something clearly in a forum post." to the list of things to learn?  :)
Don't worry. You're not the only one here with this particular problem. It's a widespread phenomenon. Don't assume that other people will be able to read your mind all the time. We don't know what's in there, so you actually have to explain what you're doing in more detail than in your first post.
Offline AG6QR
    • AG6QR Blog
Re: Zener question
« Reply #3 on: April 07, 2014, 09:47:39 pm »
Also, describe what kind of piezo device you're working with.  Buzzer?  Speaker?  Microphone?  Transducer?   While you're at it, the part number of the zener, or at least its zener voltage, might be useful.  Finally, what kind of signal are you using, and how are you determining whether it's "clipping" or "scaling"?  Where and how are you injecting the signal, and where and how are you measuring it?
Re: Zener question
« Reply #4 on: April 07, 2014, 10:04:00 pm »
the zener effectively closes the circuit with the scope being the load. It was part of a larger piece but right now I am just trying to understand the effect of the zenor. I am getting voltage regulation just not in the way I expected. Am I right to assume that the zener should clip and it is just some aspect of my setup that is causing this? Piezo's are really messy so I assumed that trying to get a predictable signal would be a good way to learn this stuff. I am one of those programmer geeks Dave talks about and I am having trouble coming to terms with the difference between ideal and real life. :)
Re: Zener question
« Reply #5 on: April 07, 2014, 10:09:10 pm »
FYI. I am not asking you to debug my circuit I am asking for a clarification of the behavior of a zener diode. I mentioned the piezo for background only. The question cannot possibly be more simple. Does a zener clip or scale? Shouldn't require a circuit diagram.
Offline sleemanj
  • Professional tightwad.
Re: Zener question
« Reply #6 on: April 07, 2014, 10:19:38 pm »
A voltage applied such that the diode is forward biased, will act like any other diode, a small forward voltage drop and current will pass.
A voltage applied such that the diode is reverse biased, will act like any other diode when the voltage is below a certain threshold, it will block the current, above the threshold current will pass with a voltage drop of the zener voltage.
Offline AG6QR
    • AG6QR Blog
Re: Zener question
« Reply #7 on: April 07, 2014, 10:22:43 pm »
The zener's behavior is described on its data sheet.  The current versus voltage curve(s) will be there.  What does the data sheet say?
The data sheet doesn't directly say whether it clips or scales, because it depends on what you're doing with it, and how you define "clip" versus "scale".
We don't know the context of your circuit, and you have ignored our pleas for information.  We certainly don't know more about your zener than the manufacturer who wrote the data sheet.  So, unless you want to provide some context for your question, I think the data sheet is where you'll have to find your answer.
Tac Eht Xilef
  • Guest
Re: Zener question
« Reply #8 on: April 07, 2014, 10:32:29 pm »
Piezo strain gauge, speaker element, or buzzer (with integral driver)? Zener in series or parallel? Value of zener?
« Last Edit: April 07, 2014, 10:35:51 pm by Tac Eht Xilef »
Offline Hideki
  • Country: no
Re: Zener question
« Reply #9 on: April 07, 2014, 10:38:45 pm »
A zener alone does not clip, nor does it scale. No, it works like a diode in both directions, with the reverse direction having a larger voltage drop than ~0.7V.
To get the clipping behavior you assume it has, you have to connect it as a voltage divider with the zener pointing up from ground and a resistor as the upper part of the divider.
When you increase the voltage, the zener will at some point abruptly start conducting and keep the output near the zener voltage, the rest of the input voltage will be found across the resistor.
I guess you have a round 'golden'-looking disk that has no driver circuitry that you're tapping with your finger to get an output (see, you never said what you did?). A rough approximation of a piezo is a voltage source (that spikes when you tap it) in series with a capacitor.
So in your case you have no resistor, there's only the capacitance of the piezo that briefly passes some current.
Re: Zener question
« Reply #10 on: April 07, 2014, 11:06:33 pm »
you are correct about tapping the golden disk :D. My question though, is more general because I thought I understood zeners until that stupid yellow disk. If you have a 0-10v sine wave and a 5v zener what will the wave look like on the other side. I assumed the top 5 volts would be cut off and you would see flat tops on the scope, but I'm not really seeing that. What I see looks more like a voltage divider. Could it have something to do with passing in and out of the breakdown voltage (very fast with a piezo)? FYI I originally rectified the signal first and had a load resistor but I pulled everything out to try to figure this out and it didn't seem to matter.
Re: Zener question
« Reply #11 on: April 07, 2014, 11:25:36 pm »
Given my limited experience  :). I have never seen a zener used in series, they always seem to be in parallel. Under what circumstances would you use a zener in series? Just curious.
Offline AG6QR
    • AG6QR Blog
Re: Zener question
« Reply #12 on: April 07, 2014, 11:27:12 pm »
On the other side of what?  A zener diode is just a two terminal device.  What sides are you talking about?  What's the source impedance of your signal?  How have you connected the zener to the signal source?  What are you measuring across? Are you measuring voltage, current, or both?
If you have a low enough impedance 0-10V sine wave, you can connect anything across it, including a 5V zener, and you'll still see a 0-10V sine wave.  The current won't be sinusoidal, though, and you might burn up your zener, depending on its ratings.
OTOH, if you have a high impedance signal (perhaps created by connecting a low impedance signal in series with a suitable resistor) you can use a 5V zener, oriented properly, to clip the voltage range to about 5V, according to the voltage/current curve in the data sheet.
Offline AG6QR
    • AG6QR Blog
Re: Zener question
« Reply #13 on: April 07, 2014, 11:34:12 pm »
Check out http://en.wikipedia.org/wiki/Zener_diode
All of the example circuits use a zener in series with something, either a resistor or another zener.
Re: Zener question
« Reply #14 on: April 07, 2014, 11:43:19 pm »
ah yeah, I actually read about the Waveform clipper an hour ago. Must be getting old. |O
Offline David_AVD
Re: Zener question
« Reply #15 on: April 08, 2014, 12:00:05 am »
Just for interest:
I've used a zener diode to drop a voltage down by a (relatively) fixed amount.  In my case the load was not constant (20-40mA) so using a resistor instead would not have worked.
As long as you do the calculation for power dissipation and ensure the zener can handle the current, it can be a cheap alternative to a voltage regulator.
Re: Zener question
« Reply #16 on: April 08, 2014, 12:14:36 am »
I don't understand this? Why would I still see the 0-10V wave? The zener is 30V which is borderline, but they are cheap and I have a bunch of them to play with. The impedance is mostly from the scope now that I have pulled the resistor. I could add it back but it didn't seem to matter and I was trying to simplify as much as possible. Maybe I went to far. The voltage is in the correct range, the wave form just seems wrong. I expected cut off peaks, but everything looks the same, just with a lower range.
« Last Edit: April 08, 2014, 12:26:06 am by tnadys »
Offline AG6QR
    • AG6QR Blog
Re: Zener question
« Reply #17 on: April 08, 2014, 02:24:20 am »
That's the definition of a low impedance voltage source.  Whatever you connect to it, it maintains constant voltage, and sources or sinks current as necessary to maintain that voltage.
Of course, in the real world, all voltage sources have nonzero impedance, and finite ability to source or sink current.  And real-world wiring or parts will fail, sometimes spectacularly, if current limits are exceeded.
Offline TerminalJack505
Re: Zener question
« Reply #18 on: April 08, 2014, 02:44:21 am »
I'm guessing that since you are using just one diode it looks like you're getting only half of the peak-to-peak output that you're expecting.  Put two zeners back-to-back and see if you get something more like what you're expecting.
Having just one zener means that it will clamp at about 700mV in one direction and the zener's breakdown in the other.
You also need to factor-in the piezo element's capacitive reactance.  You might plug the equivalent circuit of a piezo into a simulator and put a zener parallel to it and see what happens.  You will notice that the output is different than if you just put an ideal AC voltage source across a zener diode.  (Which would probably fry the zener, by the way.  So don't do that unless you limit the current.)
Re: Zener question
« Reply #19 on: April 08, 2014, 02:49:09 am »
Sorry, reading comprehension error, I though you were talking load. So Basically you overload the zener which reduces its effect. I'm not sure that is the situation in my case because it seems to be working as advertised. I just have an issue with the shape of the curve and I don't want to move on until I understand why. My results are completely consistent so I guess I'll just keep plugging away until I can find the pattern. Maybe I will use a better signal. In the end a scope is not that much different than a debugger, which is cool. To bad you can't step into parts :)
Re: Zener question
« Reply #20 on: April 08, 2014, 03:12:11 am »
No, the problem is that the shape of the + side of the signal isn't what I expected. I first noticed it when I added the zener to a half wave rectifier. I keep saying clip, but clamp is maybe a better term for this crowd. I expected the zener to clamp/clip/remove the top of the wave (anything over the 5V breakdown) which would leave obvious marks on the curve. What I am getting is a curve that looks similar but is within the 5V range (down from 30V). One thing I am thinking is that because of the signal is swinging in and out of the breakdown voltage the curve is getting distorted. I thought I read somewhere there were issues with this but I'm not really sure.
I'm pretty new to this so I apologize if this is stupid but isn't the piezo element's capacitive reactance the point of them? I am using it precisely because they are good for studying rectifiers, zeners and filters. It was an easy source of a dirty signal. maybe to easy in hindsight.
Offline David_AVD
Re: Zener question
« Reply #21 on: April 08, 2014, 03:14:03 am »
You really need to show a schematic of what you're talking about here.  Everyone is guessing based on your words.
Tac Eht Xilef
  • Guest
Re: Zener question
« Reply #22 on: April 08, 2014, 03:17:43 am »
And, if possible, a picture of the waveform that is worrying/confusing you so much...
Re: Zener question
« Reply #23 on: April 08, 2014, 03:38:58 am »
Re: Zener question
« Reply #24 on: April 08, 2014, 03:41:20 am »
The capacitive reactance will contribute to the signal's attenuation when you put a non-trivial load across it.
I don't know if that alone can account for what you're seeing, however.  If you can find a datasheet for your piezo element then you can get a better idea if that's the case or not.
