Author Topic: zener diodes  (Read 1089 times)
Offline glinjikTopic starter
zener diodes
« on: October 01, 2020, 08:36:38 pm »
hi folks is it possible to put two 1/2watt Zener diodes in parallel in place of a 1watt zener?
All the truth in the world adds up to one big lie (Bob Dylan)
Offline chris_leyson
  • Country: wales
Re: zener diodes
« Reply #1 on: October 01, 2020, 08:50:53 pm »
Unlikely because one would always have a lower threshold voltage and even if they were matched it would be risky. Current sharing resistors might help. Which Zenner diodes are you thinking of using ?
The following users thanked this post: glinjik
Re: zener diodes
« Reply #2 on: October 01, 2020, 08:56:09 pm »
18v 1 watt its part no 1n4746a
was thinking 1/2 watt 18v the voltage is not really important it can be 12-24v
Re: zener diodes
« Reply #3 on: October 01, 2020, 09:01:22 pm »
its for this soft start module VD2
Offline wraper
  • Country: lv
Re: zener diodes
« Reply #4 on: October 01, 2020, 09:05:25 pm »
If you make it with 400V dropping capacitor (C1) as it's in the circuit, very likely it will fail after some time. X2 ~250V+ safety capacitor or 630V DC rated film cap should be used.
Re: zener diodes
« Reply #5 on: October 01, 2020, 09:12:05 pm »
thank you i will change it for an x2 cap
Re: zener diodes
« Reply #6 on: October 01, 2020, 09:15:27 pm »
i suppose i could add in a emf filter and mov as an improvement
Offline srb1954
  • Retired Electronics Design Engineer
Re: zener diodes
« Reply #7 on: October 01, 2020, 09:43:40 pm »
Not really a good idea. Unless the Zeners are closely matched the lower voltage one will take the lion's share of the current and dissipate a greater proportion of the power.
A better option is to put two lower voltage Zeners in series. If each Zener is half the desired total voltage them they will share power approximately equally without any need to have them closely matched.
The following users thanked this post: wraper, glinjik
Offline ledtester
Re: zener diodes
« Reply #8 on: October 02, 2020, 03:55:56 am »
I recognize that circuit from a Kasyan TV video.
Here's a variation... pretty much same idea but they add a resistor in front of the zener and a bleeder on the dropper cap:
https://www.eeweb.com/inrush-current-limiter-soft-starter-for-ac-dc-loads/
