Author Topic: WTB 16-bit DAC with I2C interface, good ol' DIL package  (Read 3828 times)
Offline AeternamTopic starter
  • Country: lu
    • Schartz Engineering
« on: November 03, 2016, 04:10:34 pm »
Hey gang,
I suppose the title says it all. I'm looking for an I2C controllable 16-bit DAC. I found a ton on Mouser, but they're all in SMT packages which I'm not too hot about. I'd prefer a through hole model. You'd think such a thing existed, but so far, no cigar :palm:
Price is not an issue, it's for a personal project. As long as it's accurate. Vout(max) should be 5V and it should take an external VREF. :-/O
Does anyone have a tip? (apart from looking at socket adapters  >:D )
Offline Kalvin
  • Embedded SW/HW.
Re: WTB 16-bit DAC with I2C interface, good ol' DIL package
« Reply #1 on: November 03, 2016, 04:30:41 pm »
An adapter PCB SMT-to-through-hole? Shouldn't be too difficult to solder.
Offline rob77
  • Country: sk
« Reply #2 on: November 03, 2016, 04:41:01 pm »
@ farnell filtering among DACs 16 bit + DIP package yields 24 products.
  • Country: lu
« Reply #3 on: November 03, 2016, 04:59:58 pm »
None of which support I2C... See my problem? :P
Offline kripton2035
Offline matkar
  • Country: si
  • Sixty percent of the time it works EVERY time.
Offline rob77
  • Country: sk
« Reply #6 on: November 04, 2016, 09:49:30 am »
considering the price of those DACs it's n ot a problem to add a small micro to do the translation if I2C is really a must.
 btw.. what's the application ? why it has to be I2C ?
Offline julian1
« Reply #7 on: November 04, 2016, 10:39:04 pm »
Boards like these, + $60 hotair gun, + solder paste.
https://www.google.com/search?newwindow=1&biw=870&bih=582&tbm=isch&sa=1&q=soic+board+&oq=soic+board+
It's really easy - and will open up a lot of choice (and price options) for op-amps, comparators, ADCs etc.
It also means you don't need two separate inventories (SMT and DIP) for the same jelly-bean IC components.
Offline gamalot
  • Correct my English
    • Youtube
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Offline kripton2035
« Reply #9 on: November 05, 2016, 06:46:33 am »
oups !
