Author Topic: Would Need some Help to Find and Choose my first Soldering-Station  (Read 5954 times)
Offline pepslightTopic starter
« on: September 28, 2013, 01:57:42 pm »
Hi There Folks
I am getting really interested and motivated to start soldering, I found some days ago a project about how to create a Color calibration stuff for the tv. The trip is I would need first of all a Soldering station and I am really a beginner in this part of the world, so I come here to  beg for some help, I heard about the hakko 888D because the hakko 888 was discontinued, the thing is I live in Germany and I just can't find one, my budget is really really limited so I can't afford to much.
Thanks in advance peps
Offline Psi
Re: Would Need some Help to Find and Choose my first Soldering-Station
« Reply #1 on: September 28, 2013, 02:04:43 pm »
If you put a good quality tip on any cheap temp controlled soldering station it will work quite well. That will be the cheapest option.
So the real question is, what cheap soldering stations accept common tip sizes.
The Hakko 900M tips are a pretty standard size and quite often fit the cheap/clone soldering stations
hobbyking sell a $16 soldering station, i don't know what tips it uses though.
$16 is maybe a little too cheap, id be quite worried about electrical safety.
« Last Edit: September 29, 2013, 11:41:37 am by Psi »
« Reply #2 on: September 28, 2013, 02:59:00 pm »
Hi PSI thank you very much for your repply wen I mean cheap I mean I would be ready to put about 60 euros on it  :-/O Maybe more if needed I would like to later to this as a job but I could put money on side and buy something better
Offline tony3d
« Reply #3 on: September 28, 2013, 04:36:16 pm »
This one is very good, and SRA Solder is a class act. Just bought one of their power supply, and I'm very happy.
http://sra-solder.com/product.php/7113/22/aoyue_digital_soldering_station_9378
Offline Fsck
  • sleep deprived
« Reply #4 on: September 28, 2013, 04:49:15 pm »
ditto. Hakko clone with real Hakko heater and real Hakko tips.
"This is a one line proof...if we start sufficiently far to the left."
Offline con-f-use
  • Country: at
« Reply #5 on: September 28, 2013, 06:25:46 pm »
I can recommend Aoyue as well. The 9378 seems to be a clone of the Weller WD1. I own a 2738A+ since I wanted Hot-Air. If you want Hot-Air and desoldering buy the 2703A+.
Offline nanofrog
« Reply #6 on: September 28, 2013, 09:39:11 pm »
How did you come to this conclusion?  :-//
Offline AnderGl
« Reply #7 on: September 29, 2013, 07:25:33 am »
Up to $ 100. The best choice would be a clone of Hakko-936. It should select a station by weight. The harder, the better. The main thing it will transformator.On should be good. Later, you can easily upgrade your station, buying this-  http://www.ebay.com/itm/Soldering-Iron-Station-Temperature-Controller-For-HAKKO-936-T12-T1-T13-Handle-/170969190905?pt=LH_DefaultDomain_0&hash=item27ce8ed1f9. Selection will Lukey, Atten, Aouye. In this price category appropriate to propose such a thing: GOOT PX-201, Mini-Soldering Station Goot PX-601, Goot PX-501.           Excuse me for my english)
« Last Edit: September 29, 2013, 07:31:05 am by AnderGl »
Online G7PSK
  • It is hot until proved not.
« Reply #8 on: September 29, 2013, 07:47:24 am »
Try cicuit specialist, they have a good selection of soldering irons including ones that take Ayue tips, they can be found on Amazon and Ebay as well as direct from them.
http://www.amazon.co.uk/Watt-soldering-station-controlled-solder/dp/B007VC2I6Y/ref=sr_1_1?s=diy&ie=UTF8&qid=1380440434&sr=1-1&keywords=circuit+
http://www.circuitspecialists.eu/best-sellers/csi-station60w-60-watt-temp-controlled-soldering-iron-station
I would go direct rather than trough Amazon or ebay as it is cheaper for the same item that way. I got one of their irons 2 years ago and it is still going fine despite having seen a lot of work, the replacement tips they sell are marked Ayue as well.
« Reply #9 on: September 29, 2013, 11:08:54 am »
Wow amazing a loot of good awnsers!
 Thank you all For your time and patience
 I really love this forum already
So to conclude now I would be in doubt between the http://www.circuitspecialists.eu/best-sellers/csi-station60w-60-watt-temp-controlled-soldering-iron-station  or a bit more expensive the http://sra-solder.com/product.php/7113/22/aoyue_digital_soldering_station_9378
G7PSK you say that this one you propose accept Ayue tips right, Are those tips good like Hakko Kind ??? I don't have a good Idea how the tips work  |O How I can now wicht and witch is compatible ^^' Sorry really noob
A thousands thanks
Online G7PSK
« Reply #10 on: September 29, 2013, 03:12:47 pm »
They seem to be good quality tips I have been using the same tip for nearly a year now. But then I look after my soldering irons and their tips I have an Antex 25 watt iron that I purchased in 1994 that still has the same tip that it came with I also have 250 watt solon that I got in 1982 and that has the same bit both irons are used in an industrial workshop that makes and repairs generators and electric gates so get used heavily. I believe in look after your tools and your tools will look after you.
« Last Edit: September 29, 2013, 03:18:57 pm by G7PSK »
Offline nanofrog
« Reply #11 on: September 29, 2013, 03:21:18 pm »
They both use the same tip style, which are clones of Hakko 900M tips. They slide over the heating element, and the tip holder (metal tube) slides over that and screws down to keep it in place.
If you're nervous about Aoyue or other clones, you'd be able to use genuine Hakko tips if you wish (I'd suggest ordering them from an Authorized Hakko Distributor if you decide to do this, as they're heavily faked <clone tip placed in faked Hakko packaging to get more money per>).
« Reply #12 on: September 29, 2013, 03:43:43 pm »
All right Perfect thank you all, I will so buy this soldering station http://www.circuitspecialists.eu/best-sellers/csi-station60w-60-watt-temp-controlled-soldering-iron-station which you G7PSK proposed to me, Or if eventually I found a Hakko 880D would it be better than this one ?  :-//  thanks
Offline nanofrog
« Reply #13 on: September 30, 2013, 06:03:32 pm »
The Hakko would be better, but it would depend on the cost. Took a quick look at eBay.de, and there are some decently priced Hakko 888D's there, but be careful, as they're from the US and 120V (would need a 230V - 120V step down transformer, which will increase your costs).
Hakko 888D: http://www.ebay.de/itm/Hakko-FX888D-23BY-FX888D-Soldering-Station-Replaces-936-12-FX888-Solder-Station-/380727447690?pt=LH_DefaultDomain_0&hash=item58a51fd08a
300W Stepdown transformer: http://www.ebay.de/sch/i.html?_from=R40&_sacat=0&_nkw=300W+step+down+transformer&LH_PrefLoc=2&_arm=1&_armm=63&_ruu=http%3A%2F%2Fwww.ebay.de%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D300W%2Bstep%2Bdown%2Btransformer%26LH_PrefLoc%3D1%26_arr%3D1
« Reply #14 on: October 01, 2013, 08:40:12 am »
wow thank you very much Frog  :-+
Offline poorchava
  • Troll Cave Electronics!
« Reply #15 on: October 01, 2013, 08:46:18 am »
Depends on what you can get. If you live in US you probably have countless options. If not, then I'd stick with chinese stuff like Aoyue or thousand different brands that look indentically. They are not that bad in the end. Of course there's a huge gap between those and genuine Ersa or Weller (not to mention Metcal or JBC) but they do they job (I use Xytronic, which is probably a tad better than most of the chinese stuff, but still waaay worse than Ersa or Weller).
