JFYI I'm eager to share my take on jfets. According to textbooks, they always had very poor tolerances, though a bit more predictable in the same batch. So, manual binning is necessary if single jfets were used. Or a trimpot to set the operating point for a specific device.
However, for amplifier differential input stage it's much more convenient to just use a monolithic matched pair. Those are largely extinct, and cost a fortune nowadays. However, matched jfets are used inside jfet opamps, and that's preferred way to have jfet input, though a discrete solution could in certain cases give more bandwith, as I understand.
Why I asked about application. Jfets could also be used as current sources. But, in my opinion, depletion fets are better because they were a bit easier to source and gave me better tempco and compliance. This topic is covered in detail in "current sources and voltage references" book.
So, I'm not sure why one would use discrete jfets nowadays except some very rare cases. Their loose parameters make it hard to use in mass production.
