Author Topic: Will this work (optocoupler over shunt)?  (Read 8354 times)
Offline ArthurDent
Re: Will this work (optocoupler over shunt)?
« Reply #25 on: December 07, 2018, 01:44:43 am »
I would, as I said, follow the datasheet/application sheet information and, if included, would put the hysteresis resistor between pin1 (output of LM393) and pin3 (+ input) and ground the unused comparator inputs. Next I would replace the BC337 with a MOSFET and eliminate your concern of the base-emitter clamping although a resistor in series with the base would work as well.
If the collector of Q2 was connected to a resistive load I wouldn't be concerned but the relay more or less requires the added 2 diodes to eat up spikes (sorry for the technical jargon  :) ). Granted the circuit will rarely be triggered judging by the life of most lamps but I think using an inductor for the feedback point isn't wise.
We are talking in somewhat general terms here and if an actual circuit were to be built and tested I'm sure we'd find a number of other mods that would make sense.
Online Zero999
  • 0999
« Reply #26 on: December 07, 2018, 09:01:18 am »
Ideally I'd try to find a relay with a lower current draw <50mA, replace the LM393 with the LM311 and drive the relay directly, but a MOSFET is a good suggestion.
How is taking the feedback from the inductive relay coil, rather than a resistor a problem? When Q2 turns on, the collector voltage instantly falls near 0V and when it turns off, the collector voltage rises to a diode drop above the power supply voltage, until the flux in the inductor is depleted. Also only one diode is required. D7 is superfluous and will never conduct.
Offline ArthurDent
« Reply #27 on: December 07, 2018, 06:45:10 pm »
Here is my final variation of the detector that may address some concerns and, like I said, if any of these various circuits were actually built and tested there could be minor or major changes that might come to mind. I think stenespen now has enough information so they can pick and choose what they think might be best for them and try that circuit.
Online Zero999
  • 0999
« Reply #28 on: December 07, 2018, 11:17:27 pm »
That will not overcome the issue of the transistor clipping the comparator's output.
If you want to use the comparator's non-inverting input for positive feedback and don't want to use a MOSFET, then use a PNP BJT, but the logic will be reversed.
You seem not to believe me when I said the relay coil's inductance doesn't generate any noise. Where did you get that idea from? It's compete nonsense!
Here's a simulation showing an inductor being pulsed on and off with a transistor. Note that the waveform on the collector is a fairly decent squarewave. The overshoot beyond the supply voltage, when it turns off, is no problem.
Still don't believe me? Try building the circuit.
« Last Edit: December 08, 2018, 12:03:38 am by Hero999 »
Offline spec
  • MALE
« Reply #29 on: December 08, 2018, 11:14:00 am »
Below is the schematic for a precision version, with hysteresis for H99, and an  NMOSFET for AD.
The trouble is that it uses non jelly-bean components, which may not suit the OP.
Offline spec
  • MALE
« Reply #30 on: December 08, 2018, 11:23:43 am »
Living dangerously there AD. :palm:
Offline StillTrying
  • Country: Broken Britain
« Reply #31 on: December 08, 2018, 12:28:52 pm »
Isn't anyone going to do an Arduino version. >:D
Online Zero999
  • 0999
« Reply #32 on: December 08, 2018, 03:51:47 pm »
Here's a version which uses jell bean components. The turn on and turn off currents can be independently set if necessary. V2 can be the TL431 or similar voltage reference. It uses a PNP output but it can easily be modified to work with an NPN BJT, N-MOSFET or P-MOSFET.
It's a variant of a circuit I posted earlier this year, which is linked below.
https://www.eevblog.com/forum/beginners/the-simplest-thermostat-with-programmable-thresholds/msg1432025/#msg1432025
EDIT: I haven't included any filtering, which would be a good idea.
« Last Edit: December 08, 2018, 04:06:09 pm by Hero999 »
Offline spec
  • MALE
« Reply #33 on: December 08, 2018, 06:43:33 pm »
Q2 e/b junction is vulnerable here, as is the open collector transistor in the comparator. Also, you would be losing more drive to the relay than with a saturated collector arrangement, like the original.
Attached is a schematic showing  a simple and safe way to maximize drive to the relay and provide hysteresis (functionally, the TS391 comparator is just a singe comparator version of the original dual twin comparator LM393):
« Last Edit: December 08, 2018, 07:04:56 pm by spec »
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #34 on: December 08, 2018, 07:04:10 pm »
Vulnerable to what?
I wouldn't recommend running the relay coil wires to the outside world where ESD and maybe surge may be a problem.
Seven Transistor Labs, LLC
Online T3sl4co1l
« Reply #35 on: December 08, 2018, 07:07:25 pm »
What's R22-C4 for?
Q2 doesn't turn off, needs B-E resistor.
What's D6 for?
D7 is oversized, can be a 1N914 or less really.  I never got the fascination with using huge rectifiers on tiny relays... kids probably read it first in Forrest Mims' or something and kept doing it the rest of their lives? ???
Offline spec
  • MALE
« Reply #36 on: December 08, 2018, 07:55:17 pm »
I thought somehow that you would pop out of the woodwork >:(
Vulnerable to what?
If you need to ask- you would not understand the reply
Hell- I would never have thought of that!
Offline spec
  • MALE
« Reply #37 on: December 08, 2018, 08:18:45 pm »
Back again! Why don't you post a circuit for a bulb monitor yourself instead of nit picking my circuit- Oh yes, I remember now, you did once post a circuit after a lot of pushing and we saw the results of all your theories. It is a great shame that you do not apply your high standards to your own work. Tell me what are you?  Are you a design engineer who has actually designed products for the market, or are you a perhaps a consultant of some kind who gives advice and has no responsibility for the end product. I don't like your aggressive tone either- there are ways of asking questions politely.
What's R22-C4 for?
I don't believe that anyone who knows the first thing about electronic design would  ask that question!
You are nit picking. It is the architecture that is important. But as a matter of interest, show me your calculations of how much current Q2 would conduct... 1uA, 1mA, ... 100A?
What's D6 for?
So what. It is not up to you to define what components I can specify. Besides I have had this argument before from theoreticians who like to display there superior knowledge. Those of us that design products that go into the market know that it is ridiculous to design right on the edge. I have seen quite a few 1N4148/1N916 fail when used for relay snubbing and inductance catching. The 1N4148 is designed for fast low level signals. Using your criteria practically every component in circuits are overkill (a much abused word anyway).
The other thing is that the 1N400x physical construction is more robust and less likely to fracture when fitted to the pins of relays, motors, etc. By contrast the IN4148 is made of brittle and flimsy glass and with thin weedy self- leads the 1N4148 is quite simply not suited, or intended for the job of snubbing/catching. You need to consider the practical as well as the theoretical aspects of design.
And finally, what is the downside of fitting a 1N400x diode... none. So what you are saying is just a load of hot air.
What a patronizing fellow you are- I recon you still read Forrest Mims, whatever that is.
I don't know what your problem is, but on a general note, can you please stop following me around EEV, which you have been doing since I recently started posting again. You, and a couple of others, are making a nuisance of themselves and wasting my time- like now.
What I can't understand is that there are hundreds of circuits posted on EEC, some with obvious problems, where you could display your wide knowledge,  but you say not a word.  >:(
« Last Edit: December 08, 2018, 09:26:49 pm by spec »
Online T3sl4co1l
« Reply #38 on: December 08, 2018, 09:21:13 pm »
Back again! Why don't you post a circuit for a bulb monitor instead of nit picking my circuit- Oh yes, I remember now, you did once and we saw the results of all your theories.
I still don't get your thing about circuits...
You are nit picking. It is the architecture that is important. But as a matter of interest show me your calculations of how much current Q2 would conduct... 1uA, 1mA, ... 100A?
If architecture is important, the OP opened with it; indeed, I corroborated that from an analytical perspective.  Just a matter of implementation then.  Which means... yes, arguing about component choice as well as value. ???
It's about 1mA by the way, and no, it's very unlikely to cause a problem; but it's a poor design pattern that's very easily corrected, so it's always near the top of the list.
(One could also save even more with a "digital"/"prebiased" transistor, but the OP probably isn't making a million of these so normal discretes will be fine of course.)
Did I?
I'm hardly writing a dictionary over here... (cough, though I've probably posted a few of them's worth here over the years..)
Is that what you think I am, an armchair troll?
(Do you also make a habit of ignoring anyone who is right and outspoken, because clearly they must be an egoist?...)
Those of us that design products that go into the market know that it is ridiculous to design right on the edge. I have seen quite a few 1N4148/1N916 fail when used for relay snubbing and inductance catching. The 1N4148 is designed for fast low level signals. Using your criteria practically every component in circuits are overkill.
Hm, did I define a criteria?
I like the implication that I haven't made or sold anything, though.
Coincidence?  I don't care to read or reply to every single thread, just those that look of interest of course.
Indeed, when I first noticed some of your posts, I thought it very interesting -- new design blood is an uncommon sight here.  It's probably more than coincidence, if we're drawn to the same sorts of threads more than chance.
I'm sure this is my fault -- I enjoy a good rousing critique myself, and easily forget how sensitive others can be about their work.  I also tend not to emote very well in written form.  If it helps, try to read my posts with a disinterested voice.  I generally want to be helpful, or try to be; eh, not that that necessarily means anything (I can think of more than a few bad people who claimed the same thing.. the context here is hopefully very different, at least).
I probably tend to avoid threads with problems so obvious that the subject gives it away.  Hmm, clearest example that comes to mind: an ESL* struggling with a technical subject AND a language barrier.  I just can't be of much help when it's apparent that I won't be understood. :( Fortunately, the demographics here are quite diverse, and someone with better knowledge of the language barrier will be of greater help than I can.
*English Second Language.
Or, there's only so much talking I can do to a brick wall.  That 30V 3A bench supply megathread is a classic example...
Cheers,
Online Zero999
  • 0999
« Reply #39 on: December 08, 2018, 09:34:53 pm »
Vulnerable to what?
Someone else might. I was going to ask the same question: what are the base-emitter junction of Q2 and the internal transistor inside the comparator vulnerable to? Please explain what you meant.
What's R22-C4 for?
What's D6 for?
So what. It is not up to you to define what components I can specify. Besides I have had this argument before from theoreticians who like to display there superior knowledge. Those of us that design products that go into the market know that it is ridiculous to design right on the edge. I have seen quite a few 1N4148/1N916 fail when used for relay snubbing and inductance catching. The 1N4148 is designed for fast low level signals. Using your criteria practically every component in circuits are overkill.
The other thing is that the 1N400x physical construction is more robust and less likely to fracture when fitted to the pins of relays, motorrs, etc. By contrast the IN418 is made of brittle and flimsy glass and with thin weedy self- leads is quite simply not suited, or intended for the job.
  • Don't take it personally. Can't handle people nitpicking your circuits? Don't post them!
  • Why not just answer the question, rather than making a sarcastic comment? It wouldn't have taken any longer. I believe R22 & C22 are for filtering the supply to the comparator. They're not needed in this, as it's not a linear amplifier which would be susceptible to a noisy supply, hence the question.
  • He's right. Q2 won't turn off. The collector current will be dependant on the Hfe. R27 dominates and the Hfe varies widely so there's no point in including the other ones in the calculation. IB = 12/560k = 21µA. Assuming Hfe = 400, IC = 8.6mA, which isn't much, but it will cause Q2 to heat more and the Hfe to rise. It shouldn't cause thermal runaway because the Hfe will stop increasing at safe current, but it's still bad design.
  • The freewheeling diode only needs to be rated to carry the coil current. There's nothing wrong with overrating but don't be surprised when someone questions it.
You've also not said what D6 is supposed to do? It will never be forward biased!
I repeat, when posting a circuit, expect questions and criticism: both valid and invalid. I've learned when I saw someone's circuit which didn't look right, asked questions and criticised it, only to discover I was wrong, but it helped me so I don't regret it.
« Last Edit: December 08, 2018, 11:58:26 pm by Hero999 »
Online MK14
« Reply #40 on: December 08, 2018, 09:45:24 pm »
The idea of this circuit, is to be SIMPLE and made out of jelly bean parts. It is partly based on the OP's original circuit.
It does have approximately 1.5 to 2 Volts drop across the diodes, but on the other hand, simplifies things for beginners.
Edit: Updated resistor values. Feel free to adjust resistor values as necessary.
« Last Edit: December 08, 2018, 10:29:48 pm by MK14 »
Offline spec
  • MALE
« Reply #41 on: December 08, 2018, 09:55:54 pm »
Did I?
Cheers,
If I have misunderstood you, please accept my apologies. And I had no idea that English is your second language. Maybe that is partly the problem. But do try to see it from my point of view too. You and another regularly contradict/give the impression of contradicting what I say. This has two bad effects. The OP doubts what I say and it takes me ages to reply to all the adverse comments. Quite often I have had to just leave a thread because of this. And the annoying thing is that people will make an adverse remark and when you prove that are wrong, they do not apologize or even discuss it.
I hate to say this but in your post, there was only one thing that was of any significance, that is about the base resistor. You are absolutely right, but do you think that I would not have known that. And to be specific the current that could flow through the transistor (worst case) will have no effect on the operation of the circuit.
You could have just said: 'Just in case, a resistor across the e/b transistor would be good design practice'.
I am not getting at you now, but while all these obvious points are being aired, the real problems are being missed. This has happened on a number of occasions with my circuits. By the way, errors are all part of design.
So sorry Tim, I have obviously misread your intentions.
Having said that, I genuinely appreciate it when someone points out an error of significance or gives new information. :)
The following users thanked this post: MK14
Offline spec
  • MALE
« Reply #42 on: December 08, 2018, 10:07:57 pm »
Vulnerable to what?
What's R22-C4 for?
What's D6 for?
  • He's right. Q2 won't turn off. The collector current will be dependant on the Hfe. R27 dominates and the Hfe varies widely so there's no point in including it in the calculation. IB = 12/560k = 21µA. Assuming Hfe = 400, IC = 8.6mA, which isn't much, but it will cause Q2 to heat more and the Hfe to rise. It shouldn't cause thermal runaway because the Hfe will stop increasing at safe current, but it's still bad design.
I wondered how long it would be before you popped out of the woodwork too. So here we go again. Your rhetorical question shows that you have not read or understood a word of my post. And who are you to tell me what and when to post. You presume too much.
As for answering the questions directly. I gave answers. There was nothing sarcastic at all. I did mean that if I needed to explain some of those questions that the answer would not be understood. Surely you can see that as the questions were so elementary.
But any way I have replied to the third party's post, now that he has explained his position.
« Last Edit: December 08, 2018, 10:45:57 pm by spec »
Offline spec
  • MALE
« Reply #43 on: December 08, 2018, 10:25:18 pm »
Take a holiday - you just never let go do you.  |O
« Last Edit: December 08, 2018, 11:10:15 pm by spec »
Offline spec
  • MALE
« Reply #44 on: December 08, 2018, 10:34:36 pm »
About the base emitter vulnerability. That is a surprising question but if I gave an answer, like I did about the diode, you would not accept it and there would be endless posts going round and round, just like with the diode.
Another point is that, although you are all over EEC and assume the position of resident expert on all matters, you are just a member like everyone else and it is not your place to tell me that I should expect this or that or that I am obliged to explain anything.This is an example of your circular arguments. Although if someone does post a genuine question politely I am only to pleased to help out- as you must have seen on many occasions.
« Last Edit: December 08, 2018, 10:57:53 pm by spec »
Online Zero999
  • 0999
« Reply #45 on: December 08, 2018, 11:05:35 pm »
I would not accept it, because you didn't provide any explanation as to why the base-emitter junction is vulnerable. I admit i missed the part about the higher on losses, which is true, an emitter follower will have higher on losses, than a common emitter configuration. I suppose one could say the power dissipation will be higher, thus making the transistor more vulnerable to overheating, but in this case the power dissipation is only 110mW, which is well within the the rating of the BC327.
Someone else asked the same question, but you didn't say why.
Vulnerable to what?
Another point is that, although you are all over EEC and assume to position of resident expert on all matters, you are just a member like everyone else and it is not your place to tell me that I should expect this or that or that I am obliged to explain anything.This is an example of your circular arguments. Although if someone posts a genuine question politely I am only to pleased to help out- as you must have seen on many occasions.
Although I post regularly, I'm no expert on all matters, for example I know very little about programming, so I leave that to others.
You're right that no one is obliged to explain anything, but people will not accept your answers to their questions, without a clear and logical explanation.
Offline spec
  • MALE
« Reply #46 on: December 08, 2018, 11:14:57 pm »
Your reply above indicates that you havn't taken in a word that I have said.
Please keep out of my hair and I will do the same to you.
________________________________________________________________________________________________________
« Last Edit: December 08, 2018, 11:18:44 pm by spec »
Online Zero999
  • 0999
« Reply #47 on: December 08, 2018, 11:44:13 pm »
Yes that'll work, but the logic is reversed. R3 and D3 could go in the emitter, to make the LED off when the lamp is blown and on, when it's working.
I agree, the circuits have become outlandishly complex and overkill, but that's feature creep and people having fun, posting different solutions. :)
Online MK14
« Reply #48 on: December 08, 2018, 11:52:50 pm »
I guess the OP, hasn't necessarily been 100% clear on, if they want it on or off, when faulty.
I based the logic, on a diagram, similar to the following one, shown below.
I.e. It ONLY lights up when the bulb is blown/faulty and needs replacing.
Online T3sl4co1l
« Reply #49 on: December 09, 2018, 02:34:30 am »
Not me, I mean examples of threads by original posters (OPs) that are.
It is easy to misread criticism as contradiction, but please do not jump into a defensive position when you see such a statement!
All that I have said about myself, probably applies in part to Hero999 as well.  He's been here longer than I have, and I don't recall any particular disagreements.  If I may be so bold: you seem to be the common denominator here, so please, take it easy! :)
Could.
I'm very thorough in my work, and I try to present that here in the hopes that others will pick up on it.  The design process can go infinitely deep, but you only need to go finitely far to get an arbitrarily good result.  That is, it is a process where successive approximation yields excellent results (as opposed to some processes that diverge -- sometimes this happens in SPICE for example, with subsequent hair-pulling..).
So, in that process, rather than leave it at the zeroth or first approximation, I do a quick second-order check to verify that the first degree is, in fact, the correct stopping point, and that no big surprises are likely to show up.
And so, in that process, I make observations, look for weird things.
If I see something that doesn't have an obvious purpose, I ask.  I mean, asking questions are how we find out about things, right?  Can I never ask you a legitimate question ever?  That's really unfair, man.
To paraphrase Freud, sometimes a question is just a question.
Sometimes a question reveals insight.  Is there actually no reason for R22-C4?  Might as well remove it, then.  Fewer parts in a discrete design, easier to assemble, less to go wrong.  That's valuable.  Or replace it with something better suited, like if inductive spikes and reverse protection are a concern, then a TVS diode would be even better.  (And if this is an automotive application, both are likely!).
And so our circuits can improve, and we learn more breadth of knowledge in the process. :)
(Professionally, a typical response to a question like this is: "it was copied from a previous design".  That's a possible warning sign -- many designs build up technical debt just as much as software or facilities do.  But it also at least strongly implies that it's passed functional and regulatory checks before, and is worth consideration.  Another typical response is: "yeah, we're not really sure there, we just pulled from the appnote", and useful improvements can be made -- and often prove necessary!)
