The element is ceramic, its resistance increases as it gets hotter which reduces the current.
So it naturally regulates temperate to the correct level for hot glue.
If you look on the side you may notice the gluegun is 110-240V. It gets up to temp faster on 240 but 110 gets up to peak temp just the same due to this natural temp regulation.
