Author Topic: Will strain resistance will go up  (Read 2800 times)
Offline A2Topic starter
« on: August 08, 2014, 06:54:08 pm »
I have a strain gauge of 1000ohm, with 50000 microstarin & GF=2 it can exhibit a change of 100ohms.
Do strain resistance value will always go down i.e 1000-100 = 900ohms.
or it can go above 1000 ohms. Like 1000+100 = 1100ohms
Offline fcb
    • Electron Plus
Re: Will strain resistance will go up
« Reply #1 on: August 08, 2014, 07:12:58 pm »
Depends on the direction of the strain.  One way it's resistance will increase - the other it will decrease.  1000ohms is the nominal value.
« Reply #2 on: August 10, 2014, 12:18:06 pm »
1. I am using strain gauge from vishay whose datasheet i have attached.
2. I know that in compression resistance decrease & vice versa.
3. But in datasheet it says only, strain range = 5%. For gf = 2 & R = 1K, total change in resistance will be 100ohms.
Now does that resistance will go 100 ohm down(i.e 900ohm) in case of compression
& in case of tension it will go up 100 ohm (i.e 1100 ohm) to show maximum strain i.e
5% or 50000 microstrain
This is what i am asking?
« Last Edit: August 10, 2014, 12:20:07 pm by A2 »
Offline f5r5e5d
« Reply #3 on: August 10, 2014, 01:27:01 pm »
most things I've see strain gages glued to don't do  +/-5% strain - or at least not twice
for good force measurement you usually use a metal structure in its linear elastic recovery range, which is less than 0.5% strain
and most measuring devices are used with a safety factor to not permanently bend the completed load cell
so you most often end up with less than 0.1% resistance change
of course if you are into destructive testing/plastic deformation you may see more
Offline fcb
    • Electron Plus
« Reply #4 on: August 10, 2014, 06:15:30 pm »
Read: http://www.vishaypg.com/docs/11506/gageser.pdf
Whilst +/-5% is the limit, I would be nervous about subjecting a strain gauge to a tenth of that (and maintaining any sort of accuracy), I think the adhesives would also be a problem.
And in answer to your (specific) question: yes
