Your DSO150 is a newer version than mine, but to reset the vertical position on mine, I disconnect the leads, move the input switch on the back to GND, then hold the left button down until it says it's resetting the vertical. That moves the left indicator to the middle, and that's also where ground is. Then I move the input switch back to DC and test the squarewave generator on the back, which should give you a square wave from ground to 3.3V. I don't know if the newer versions work the same way.
