Author Topic: Will a TO-252-5 breakout board work for plain DPAK ?  (Read 2866 times)
Offline Back2VoltsTopic starter
« on: January 06, 2017, 02:53:29 am »
I would like to adapt a DPAK for testing in breadboard.   I found the adapter in the picture.   Am I right in assuming that it will work?
Offline ebclr
Re: Will a TO-252-5 breakout board work for plain DPAK ?
« Reply #1 on: January 06, 2017, 03:59:58 am »
You may need a heat sink
Offline mmagin
« Reply #2 on: January 06, 2017, 04:50:50 am »
« Reply #3 on: January 06, 2017, 04:52:17 am »
That would not be a problem.   I can glue on something a 9x9x5mm.
« Reply #4 on: January 06, 2017, 05:13:12 am »
DPAK is TO-252.  I think the leads on TO-252-5 are narrower, maybe you can fudge it though.
http://www.irf.com/package/hexfet/dpakfootprint.pdf
http://www.infineon.com/dgdl/PG-TO252-5-12-Package_Overview.pdf?fileId=db3a304319c6f18c0119ce64c5187b30
I see what you mean.   They have to be narrower to fit the additional pins between extremes and center.   The DPAK side pins may overlay into the nearest footprint, which would be a problem if the center pin in the DPAK had full length and in turn overlay the same footprint, creating a short.    As it is cut short, it will probably work.
