Hi all.
I am wanting to cheaply make a circuit that uses one noise to trigger the output of another. Namely, a live drum beat via a microphone to cause the audience to briefly hear the output of a piano-keyboard.
I was thinking of using the attached circuit to detect the drum hit. But replace the LED with the input side of zero-crossing triac-output optocoupler whereby the triac output permits current to flow from the line-out of a keyboard which is already playing.
Does this seem practical? I am not asking about the section of the circuit which is highlighted, I just happened to screenshot-it when that was happening. I am aware that it will need tuning for sensitivity and duration. I was however, considering dispensing with the comparator entirely and simply allowing the optocoupler's LED to fade-out gradually, according to the time constant of the capacitor.
