Author Topic: Why output comes before the collector on single transistor amplifiers?  (Read 2167 times)
Offline gkmaiaTopic starter
  • Electronics Hobbyist
I thought the:
- clean current would get into the transistor through the collector
- the signal inserted through the base
- the current from the collector would combine itself with the signal
- that would emit from the emitter an amplified signal
but by looking at most circuits that amplify with one transistor they all place the output before the collector. Why?
Offline oPossum
Re: Why output comes before the collector on single transistor amplifiers?
« Reply #1 on: January 31, 2019, 04:37:38 am »
A common emitter amplifier like that has voltage gain.  A common collector (emitter flower) only has current gain.
Offline TrickyNekro
  • Country: gr
  • Drinking Frappé on the way to Isomnia!
    • Youtube channel, electronics and more ;-)
« Reply #3 on: January 31, 2019, 04:43:38 am »
If you have the money to spare Sedra Smith is a wonderful book to read.
Though you could surely find it in some "dark" places on the internet, for me it´s really worth having in your library if you are serious about electronics.
The issue is a bit more complicated than you might think to just reply in a few sentences. It´s more like pages upon pages in books.
Cheers!
If you are an engineer and you are not tired...
You are doing it wrong!
The following users thanked this post: gkmaia
« Reply #5 on: January 31, 2019, 07:41:09 am »
In this configuration the transistor is a voltage controlled current source. The resistor is a current to voltage converter. Try and think of it like that as two separate devices.
Voltage -> current -> voltage
It’s a bit more complicated than that really but the basic idea is a valid mental model.
« Last Edit: January 31, 2019, 07:42:58 am by bd139 »
Online vk6zgo
« Reply #6 on: January 31, 2019, 08:03:48 am »
I thought the:
Because that's not how transistors, or FETs, or vacuum tubes (valves) work!
Imagine, if you will, the transistor in your Schematic being replaced by a variable resistor with a knob you can turn to increase or decrease the resistance.
This device, which we can call VR1, along with Rc, forms a voltage divider between your "power source" & ground.
The "output signal" is the voltage between the junction of Rc & VR1, with respect to ground.
If you move the knob controlling VR1 fast enough, you get a varying voltage at the output which looks like a very low frequency audio signal .
Imagine if you had superpowers, you could listen to some music & twiddle the knob in time with it.
If you listened to the signal with an amplifier & speaker, you would hear music!
Unfortunately, nobody has super powers, but early experimenters looked for ways to vary the resistance of part of a voltage divider to do something along those lines.
The first success was the carbon microphone.
The sound of someone speaking into the microphone varied the resistance of the resistive element, & hence, varied the voltage available at the output of the voltage divider made up of that element & its load resistor--- in many cases, the  earphone of  a telephone somewhere remote from the mic.
This gave them a very sensitive microphone, but it still didn't solve the problem of amplifying a signal which was already an electrical one.
One idea was to use a very sensitive earphone, mechanically coupled to a carbon mic.
This worked, but not too well.
Ultimately, the first workable vacuum tubes were made, revolutionising the field of Electronics.
The "tube" was still a "variable resistor", but one where the input signal controlled the amount of current flow through it, & hence, its effective resistance value in the "voltage divider".
Most amplifying devices, although the mechanism varies significantly, still  are "part of a voltage divider".
Some circuit configurations are a bit hard to visualise as a simple "voltage divider", but it works well with the "Common Emitter" & " Common Collector"(Emitter follower)  circuits, & their equivalents with other devices.
Offline TrickyNekro
  • Country: gr
« Reply #7 on: January 31, 2019, 12:20:13 pm »
this one?
http://global.oup.com/us/companion.websites/umbrella/sedrasmith/
Yup, that one. I got the fourth edition, so I do not know what they added or removed, still, I very good read!
Offline hli
« Reply #8 on: January 31, 2019, 01:46:18 pm »
RSD academy has a nice youtube video explaining common-emitter amplifiers:
Offline rstofer
« Reply #9 on: January 31, 2019, 02:36:24 pm »
W2AEW explains amplifier configurations quite well:
