Hi!
I'm trying to understand how the switch inside the MC34063 works. I've put together a test circuit.
I thought I'd see a rectangular waveform on pin 1, the switch being open for 6t and pulling pin 1 low to ground, then the switch being closed for 1t and letting pin 1 go high to supply voltage trough the resistor. Here's what I measure, though.
The probes are 10x, so vertically one cell = 1V. The upper trace is from the timing capacitor (pin 3). The lower trace (on pin 1) I don't quite understand.
When the switch is open, pin 1 is slightly above ground (PN junction voltage?). But then when the switch closes, the trace abruptly falls below 0, and then it slowly climbs up but not anywhere near the supply voltage. I can also see that it's "accelerating", the increase begins slow and then goes faster and faster.
Can anyone tell me what is going on here?
