Author Topic: Replacement part for an RS-485 isolated transceiver  (Read 92 times)
Sorama, Ian.M and 2 Guests are viewing this topic.
Offline FreshmanTopic starter
  • Country: in
Offline PGPG
Re: Replacement part for an RS-485 isolated transceiver
« Reply #1 on: Today at 12:40:39 pm »
Your original IC have integrated isolated DCDC converter while your alternative IC don't have it.
The following users thanked this post: Freshman
  • Country: in
« Reply #2 on: Today at 02:06:34 pm »
Thank you. So, just a clarification.
Could you please suggest an alternate part that would be a good replacement for the Original part? I tried in Digikey and mouser but couldn't find one correctly
Offline PGPG
« Reply #3 on: Today at 03:28:55 pm »
If I knew the replacement part I would write, but to search it I have no time.
When 20 years ago I was using isolated RS485 I made it with 3 elements:
- signal isolator (one from ADuM serie),
- DCDC isolated converter,
- standard RS485 transceiver.
Never used part like you have.
