I have a sensor that gets dropped into a hole. It's size contained. I might be able to recover it, but might not, so I need pretty cheap costs.
I plan on feeding it with a lipo cell, but I need a lot more than the 3.7V of a fresh cell and momentarily, I need .5W spikes of power for short amounts of time. So I need a boost circuit to get the voltage up, but then I get a little lost.
I think on a LiPo cell, that those typically "short" pretty well. That if I have a 3.7V 100mAh cell, that I "could" get 48V and 10mA from that, but it would be the ESR that is the main limiter.
Then the boost circuit's response and efficiency.
Then that the battery will quickly drop from 3.7V.
Am I missing anything? It seems like it's fairly straight forward things, but there has to be some extra difficulty. For example, what are the chances I could get .5W instantly from some China 3.7V? If I want to figure this out for a specific battery will I need an ESR meter?
