Author Topic: Is LTSpice an appropirate tool to use to model digital circuits?  (Read 4066 times)
Offline JoeNTopic starter
  • We Buy Trannies By The Truckload
By digital circuits, I mean transistor circuits working as digital circuits where the circuit is modeled up from transistors up to gates, more complex subcircuits, and finally state machines.  Right now I modeled a RS flip flop and built a test circuit to use it as a frequency divider, just as a test.  I think it is quite interesting how as an analog simulation it shows you the slew of the transistors (especially when it is run at a faster clock), voltage excursions, etc.  Is this the way to do it?  Or is this insane?  How well is this going to perform if there are a few thousand transistors in the simulation?
Comments or advice would be appreciated.
Basic gates:
Inverter
2-NAND
3-NAND
The RS flip flop:
The testbench circuit:
The results:
« Last Edit: August 10, 2016, 05:50:41 am by JoeN »
Have You Been Triggered Today?
Offline bobaruni
Re: Is LTSpice an appropirate tool to use to model digital circuits?
« Reply #1 on: August 10, 2016, 09:57:53 am »
Looks good and if it works for you, why not!
Simulations will start to slow down the more components and signal paths you have.
Also, there are a few digital gate components built into LTSpice's shipped library.
I just wonder though, if you are going to design something using thousands of transistor, it might be time to look at something like CPLD/FPGA.
Online rstofer
« Reply #2 on: August 10, 2016, 01:33:26 pm »
Or at least use the toolchain for the CPLD/FPGAs.  Most have schematic entry and many have simulators.  There's a bit of a learning curve to using the toolchain and describing circuits but they can be described at the gate level.
Try the free version of Xilinx Vivado.
