I have a 74HC112N, dual negative edge triggered JK flip flop with preset and clear. I want to set it to toggle mode, which I know how to do in terms of what the inputs need to be, but when it comes to wiring it up, I'm not sure how to configure the inputs. They can't be left floating, I know, and the datasheet says to tie unused inputs to either Vcc or GND. But it makes no mention of pullups. So, can I just wire J and K to Vcc, PRE and CLR to Vcc (they are active LOW) and be OK? (I'd tie all inputs for the second FF to Vcc I suppose.) My impression is that if I attached switches to J and K, I'd need to use pullups to keep the inputs at logical 1 (or pulldowns for logical 0) so that I don't short out the pins when I push the button.
