Hello,
My LG plasma tv made some pop sound and stopped working. I opened up its back and with a multi-meter found out that that a fuse is blown. There may be other things wrong too but multi-meter connectivity on the fuse didn't work.
Markings on fuse are such Lf (for little fuse?) T10A H 250 VP. It think its a 10 amp 250v ceramic fuse. right? I found out that home depot carries a similar type of fuse. Link :
https://www.homedepot.com/p/Cooper-Bussmann-ABC-Series-10-Amp-Silver-Electronic-Fuses-2-Pack-BP-ABC-10/100207527The fuse does not have a wire attached at both ends. Can I add wire/lead on on the fuse? if yes, how?
I also found this fuse on mouser.com. Link
https://www.mouser.com/productdetail/?qs=TSScP84zSErMyPHYOJM52Q%3D%3D.The fuse on mouser does have leads/wires at the ends. Ordering them will mean I will have to wait days for them to arrive. From home depot, I can get in 30 minutes.
So, in essence - I want to find
1) what are these types of fuses called - Axial fuses or Cartridges?
2) Can I buy these cartridge/axial for the fuses and attach them to a fuse? If so, from where?
Thanks,
