I prefer to make my own flux since it's a lot cheaper and you can make it as thick or thin as you want.
Just get some rosin and crush it into a fine power, mix with a small quantity of isopropyl alcohol and leave for a day or so.
It works just as good as the most expensive stuff, although it's not as aggressive as some so you don't need to clean it.
