That's the usual place, in order to avoid over-driving any of the stages.
Once the first stage overloads, there is no way to avoid the distortion in the signal.
The only reason not to put it before the first stage is if the signal into the volume control is so low that the noise contributed by that stage would degrade the signal/noise ratio.
