Poll
Need to share knowledge on remote interface
Share knowledge
2 (100%)
Work together
0 (0%)
Total Members Voted: 2
Author Topic: FLUKE 189, 289, 789  (Read 777 times)
Offline EJAPTopic starter
FLUKE 189, 289, 789
« on: May 08, 2024, 12:10:52 pm »
Hello, sorry for my English. I would like to know if somebody still work on ir remote interface for fluke 189, 289, 789, ...
I would like get all message protocol and it's meeting . I just find and know how the crc is computed and I would like to work with some enthusiasm people about that.
Thanks a lot
Eric for EJAP Technology
Online coromonadalix
« Last Edit: May 08, 2024, 12:25:45 pm by coromonadalix »
Re: FLUKE 189, 289, 789
« Reply #2 on: May 08, 2024, 05:31:37 pm »
Hello, yes I get this paper, but I speak about a real protocol implemented on fluke 289 , each frame start by 10 02 ... 10 03 crc. I have already discovered many parameters and possibilities, more than the 6 ASCII 2 bytes commands
Eric
« Reply #3 on: May 09, 2024, 01:55:34 am »
1st   dont mix  the 187 189   with the 287 289 series  they are not built the same
if by miracle they share the same protocol  ... that's another thing, i dont catch what you mean by real protocol ??    they are defined in the following
a better google search  give this
https://www.uniteng.com/neildocs/facilities/Fluke289_remote_spec28X.pdf
or
visual studio  you see the commands
https://www.vbforums.com/showthread.php?835765-VS-2010-How-do-I-talk-to-a-Fluke-289-DMM
http://craftsman-hambs.blogspot.com/2010/02/fluke-189289-dmm-connect-to-computer.html
« Last Edit: May 09, 2024, 02:00:40 am by coromonadalix »
Offline BeBuLamar
« Reply #4 on: May 09, 2024, 10:20:52 am »
The 187/189 and the 287/289 use the same IR to RS-232 (or USB) cables so electrically they are the same but the protocol are different. I don't know what the OP is trying to do. If he wants to make the cable then they are the same (except for the way of attaching the IR to the meter, the Fluke cable came with the adapter to use with the 187/189). If he wants to write the software then they are different.
« Last Edit: May 09, 2024, 10:22:48 am by BeBuLamar »
« Reply #5 on: May 09, 2024, 12:28:22 pm »
Hello, today I have made a big progress . I know that ASCII protocol or binary protocol use the same string. In fact the 10 02.... could be use on hard environment when you should be sure the exchange is working well. I have discovered more that 6 more important message to get info and set info on FK287 (I will check on 289 later).
Eric
Offline Kitesurfing
« Reply #6 on: August 15, 2024, 01:32:55 am »
Hi All,
I'm looking for the non documented remote functions for the Fluke 789.
Looking for a command to increase and decrease the 4-20mA steps for an automated calibration test I'm coding.
Normally I would use the emulate keypress, eg 'SF 10' they don't work for me, I away get a fail response '1'
All the ascii command like ID QM etc work fine,
but I'm looking for the set function commands or equivalent (Ascii or Hex format),
If anyone has any functions to try, please PM me
Thanks in advance.
