Author Topic: hard drive engine  (Read 742 times)
Offline Adrian_Arg.Topic starter
  • Country: ar
hard drive engine
« on: February 19, 2023, 12:15:34 am »
I have a question, I have several hard drive motors, but all with three pins, and the schematics that I have seen are for four cables, using irfz44n, in those with three cables, what would be the correct schematic?
Offline DC1MC
Re: hard drive engine
« Reply #1 on: February 19, 2023, 12:19:05 am »
https://www.electroschematics.com/hdd-bldc-motor/
Is three-phase engine, maybe triangle connection:
« Last Edit: February 19, 2023, 12:25:04 am by DC1MC »
Offline Whales
    • Halestrom
« Reply #2 on: February 19, 2023, 02:26:13 am »
At a vague guess:
4 wires = 2 coils
3 wires = 3 coils in a "delta" or "wye" "3-phase" configuration
« Last Edit: February 19, 2023, 02:27:50 am by Whales »
Offline Doctorandus_P
« Reply #3 on: February 19, 2023, 09:13:47 am »
The video linked to by DC1MC also uses a 4 wire connection, but with 3 MOSfets. This suggest a Y conncection for a 3-phase motor.
If you only have 3 wires, then you need three half bridges instead of 3 MOSfets. The motor itself is just a BLDC motor, and any motor controller that can do sensorless drive for a 12V motor should work.
