Author Topic: What makes a high end audio amp "better" then a low end unit?  (Read 53375 times)
Online BrianHG
    • LinkedIn
Re: What makes a high end audio amp "better" then a low end unit?
« Reply #200 on: November 05, 2017, 10:00:49 am »
9. What are the best speakers you have heard that make the best compromise between bass response and stereo imagery?
Headphones.
My Clements RT7 tower speakers outperforms GradoLabs SR1 headphones with stereo imagery even down to their astonishing flat 25Hz response.  In fact, with properly down-converted to stereo DTS bluray movies, I've had sub-sonic effects start out in front of you, move right through you, then felt behind you as imaged by the location of the effects in the movie.  Try doing that with a mono sub-woffer.
Offline Psi
« Reply #201 on: November 05, 2017, 10:13:34 am »
i'm a Klipsch person myself. Just love how clear they sound.
yep, Klipsch reference series for speakers and a good ($250+) pair of sennheiser's for headphones.
Offline hamster_nz
« Reply #202 on: November 05, 2017, 11:01:17 am »
Headphones.
Are you able to explain how we avoid constructive/destructive interference effects that occur when you have two (or more) speakers, vs when you have a single source (like an real musical instrument)?
An A6 (1760 HZ) is about 20cm long, so with a sound on the center all it takes is a a speaker 10cm closer than the other (about half a head) to have destructive interference on the fundamental, leaving you only with reverb from the room...
Online Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #203 on: November 05, 2017, 11:10:43 am »
This thread makes an interesting reading in some respects. I would like to make a brief summary:
1) There is apparently a religion - worshipping DBTs. Any objections or doubts rejected out of hand without a discussion by its adepts  |O . Nobody said that he/she did participate in at least one properly constructed DBT, so this looks like a pure leap of faith.
2) No replies to my simple question - if any of participants did design a Hi-Fi production amplifier. So no direct experience with the subject is admitted.
3) Suddenly, there is an agreement that speakers and microphones are not as easy as amplifiers, being mysterious mechanical  contraptions beyond the simple electronics world limits  :-DD .
4) The simple fact that an audio power amplifier has to deal quite intimately with that strange speaker creature somewhat escapes attention.
As the result, the level of discussion (with few exceptions) is at a kindergarten stage. Which is appropriate for this Beginners section  :-+ . Perhaps one day we may have a reasonably serious discussion about power amplifiers design. There are some interesting nuances there. Like how a non-linearity of the output impedance of the amplifier may affect the sonic performance (and why). Or how non-linear and delayed signals generated by a speaker and injected back into the amp's output affect the sonics depending on the amp's ability to deal with these. Or what are the effects of a power supply size and energy storage (and why, for example, that patented "Class I" Levinson amplifier linked here earlier uses a very conventional power supply technology with a huge and heavy toroidal transformer plus lots of large capacitors  ::) ).
Cheers
Alex
« Last Edit: November 05, 2017, 11:14:02 am by Alex Nikitin »
Offline Zero999
  • 0999
« Reply #204 on: November 05, 2017, 11:48:18 am »
Because no, logical, well-thought out doubts to DBTs have been raised. They are used by the scientific community in other fields. The fact is, if no one can tell the difference between how amplifier A and B sound, then there are other factors which need to be considered in deciding which is better.
Not as such but fairly recently, I've been involved in designing a new intercom for a noisy environment (both acoustically and electrically) at work. What's amazed me is how good cheap amplifier ICs are.
There's nothing mysterious about the fact that amplifiers introduce less distortion and audibly transparent compared to the transducers connected to either ends of them. It's backed up by solid science. Audio amplifiers don't need to be any "better" than they are today. They're already better than the human ears, speakers and microphones, so improving them further is a wasted effort.
Cheers
Alex
Speakers are fairly benign, compared to what other power supplies and amplifiers have to put up with, yet not the same level of nonsense surrounds them as audio amplifiers. It just defies logic.
« Last Edit: November 05, 2017, 03:42:59 pm by Hero999 »
Online Alex Nikitin
    • A.N.T. Audio
« Reply #205 on: November 05, 2017, 12:40:04 pm »
Please note: you are using logic and common sense, which is fine, however I speak from many years of experience in the field. Logic is only good if the input is accurate and sufficient. Otherwise, logic is a very good instrument for fooling yourself.
Cheers
Alex
Offline _Wim_
« Reply #206 on: November 05, 2017, 12:44:35 pm »
Cheers
Alex
1) I have done several tests in the past to try and hear the effects of introduced all kinds of distortion. Tools used:
- ABX plugin for foobar: http://www.foobar2000.org/components/view/foo_abx . This plugin allows you to compare 2 sound tracks, were you have modified one with distortion, and the other not. Then you can try to distinguish between the two with the software randomly playing one of both
- Distorter VST plugin (can seem to find it online any more). Other VST plugin to generate distortion should work equally well.
- Good headphones (Sony MDR-V6)
=> my conclusion: it is not as easy to hear it as I thought it would have been. It for example also interesting to compare lossless with varies MP3 formats
2) I have built amplifiers (but mainly based on designs by others), measured quite a few, even sold a few, but it was not a viable business for me (unfortunately, would love to be in the audio business, but it is difficult)
3) problems with speakers and microphones is they radiate/record in 3D, resulting in an infinite amount of "signals". An amplifier on the other hand is only a single point in this space. If a speaker would radiate equally in all directions (point source), equalization would be very easy with DSP. Just record the impulse, calculate the reverse, download it to a DSP-convolver, et voila, a perfectly flat response…
4) If you mean the amplifier becomes unstable under certain load conditions, I would not classify this amp as "well designed. When measuring the amplifier parameters, I agree one should use a realistic load (no problem using even a real speaker, only for measuring at max power, this might be “slightly annoying”)
By making statement the discussion is at kindergarten stage and beginners, you do indeed ensure this is true...
“Like how a non-linearity of the output impedance of the amplifier may affect the sonic performance (and why).”
Output impedance is mainly determined by the amount of feedback. If non linearity’s exist, these will show up in the IMD distortion plots. For this it might also be necessary to test with burst signal (transient intermodulation distortion). From what level of distortion this is audible is open for debate, but please feel free to state what your minimum distortion level is for good sound…
In my opinion levels below 0.03% (-70dB) are readily achievable and more than sufficient (try it with the app above to see if you can easily hear this!).  At low power levels this can even be decreased to  0.1% because it will be buried down deep into the noise.
“Or how non-linear and delayed signals generated by a speaker and injected back into the amp's output affect the sonics depending on the amp's ability to deal with these”
An amp with very low output impedance act as a true voltage source, back emf is handled by the negative feedback. If not it will show up as measurable distortion.
Somewhere in this thread you stated that some audible things cannot be measured, please tell me one design choice that make a difference that will not show up in measurement. From the examples you have given so far, this is not the case
P.S: you still did not reply to my remark on DBT that it should work perfectly to check for audible differences (same as with the foobar app above)
Online Fungus
« Reply #207 on: November 05, 2017, 01:25:29 pm »
Huh? Your only "argument" is that DBTs don't work because nobody can provide a link to one.
I can provide links to CEOs of audiophool companies running away screaming from DBTs, even when offered a million dollars to participate.
None is necessary.
a) Nothing sudden about it, and
b) The two aren't related. The "best" amplifier in the world can be fully characterized without connecting a single speaker to it. We can use it to know what the desirable properties of an amplifier are.
Jeez. If only Electronics Engineers could know what those things are. And how to measure them.  :palm:
You yourself claim to have designed an audiophile-grade amplifier that retailed for 300 pounds. You're actually disproving your own point every time you mention it, ie. you're demonstrating that amplifiers are a solved problem.
Online Fungus
« Reply #208 on: November 05, 2017, 01:36:51 pm »
Please use logic to explain why a DBT won't work.
We can start with easy stuff like speaker cables.
(which have had DBT done to them, with predictable results)
Online Fungus
« Reply #209 on: November 05, 2017, 01:40:25 pm »
I can easily change a component in an amplifier to a different value (with a measurable difference if you know what to measure, but nothing changes in measurements commonly used to qualify an amp's performance).
You still haven't told us what this secret measurement is that nobody else knows about.
Online Alex Nikitin
    • A.N.T. Audio
« Reply #210 on: November 05, 2017, 02:19:17 pm »
An interesting observation - people try this kind of experiment and happily accept that there is no difference you can hear if you can not sense it under these conditions. No one seems to question the validity of the test itself. As I've said earlier, our perception is very bad when dealing with a repeated stimulus. Thus when you try to build up a number of samples required for a proper statistical analysis you reduce the sensitivity almost to zero for the small differences we are trying to sense.
We are not talking about bad designs. However, I should note that a very low output impedance over a wide frequency range and an ability at the same time to work on any real-world reactive load are not easy to achieve in a typical amplifier relying on a global NFB for linearity.
"Very low output impedance" and "true voltage source" are relative terms. And same as with distortion levels it is open to interpretation on what is acceptable. From my experience there is no simple and fast rule on any of these. No amplifier is perfect in all respects, even these designs which try to push linearity as far as possible (i.e. Halcro).
On DBT see above. There are too many problems with these tests, essentially DBTs are not sensitive enough for the stuff we are trying to deal with. The easy way is to dismiss sonic variations not detectable in a DBT as non-existent, however for an amplifier designer it is a counter-productive approach, you are just fooling yourself and eventually your customers.
On measurements - a great deal can be measured but to establish a definite link between these measurements and listening experience is difficult to impossible at the levels of quality we are trying to achieve. On what to measure - a simple example. You replace the mains transformer in an amplifier to a somewhat more powerful one, providing the same voltage under load so there is no change in the measured output power, distortion, frequency response, transient response etc. Would it affect the sound amplifier makes - more than likely. So what do you need to measure to see the difference? It is certainly a measurable difference. What could you do to correct the sound to accommodate a different transformer?
Cheers
Alex
« Last Edit: November 05, 2017, 02:21:28 pm by Alex Nikitin »
Online Alex Nikitin
    • A.N.T. Audio
« Reply #211 on: November 05, 2017, 02:30:28 pm »
It is up to some degree a solved problem for me. Could you do the same   ::) ?
Cheers
Alex
Offline Zero999
  • 0999
« Reply #212 on: November 05, 2017, 04:20:31 pm »
Question to pose: Since audio PWM tech is here to stay, for analog buff's can it be improved?
I submit this from attached PDF (Re: Model No53 from Levinson corp): (Are they hitting on any good audio future here?)
With conventional switching amplifier designs (Class D and other variants), the output stage is theoretically limited to a single interleaving topology, which limits the audio passband frequency range, and results in high order distortion products that must be filtered out with brickwall filter types, which can introduce phase errors and other in-band artifacts. Care must be taken to ensure timing accuracy, as dead time (brief moments where neither the positive or negative stages are conducting current between pulses) and overlap (brief moments where both positive and negative output stages are
simultaneously conducting current, which is a catastrophic condition that can cause amplifier failure) must be thoroughly addressed.
With our Interleaved Power Technology, there are eight half bridges (N=8) working synchronously to achieve a much higher PWM switching frequency (4 MHz). The modulation circuitry also features propriety refinements to ensure that there is absolutely zero dead time between pulses, as well as completely preventing the possibility of overlap.
The charts below detail the tremendous improvements in bandwidth and low distortion provided by our Interleaved Power Technology (N=8), compared to conventional Class D (N=1) techniques.
They give 2 charts:
1) Sample Standard Class D output (N=1) 100 kHz, sidebands and odd harmonics are all present
2) Sample IPT (N=8) with extremely marginal residuals around 800 kHz
With Interleaved Power Technology (N=8), the comparably much smaller byproducts of the PWM switching process are easily filtered out using a simple high frequency notch filter, which has no deleterious effect on sound quality, compared to brickwall filter types.
And, the broad frequency response provided by our Interleaved Power Technology system is ideal for the latest wideband high resolution audio formats, with extended response all the way out to 95 kHz (-3dB, 8 ohms).
Once the 5 or 10 year patents expire, could we expect anything better from PWM?
I doubt it will objectively sound any different to any other modern class D amplifier. It sounds like more marketing, than anything else. A -3dB bandwidth of 95kHz for an audio amplifier? That seems like a liability, rather than an advantage!
The harmonics on the plot are mostly well above the audio band (even the second, 10kHz, is 55dB down on the fundamental, which shouldn't be noticeable) so removing them will make no difference to the perceived sound. It's interesting they don't show spectrograms with other input frequencies than 5kHz, probably because that's the worst case scenario.
This set up might be theoretically better for RFI and efficiency, but the results don't seem to indicate this and no comparison is made to a standard class D design.
The following users thanked this post: Cliff Matthews
Offline Electro Fan
« Reply #213 on: November 05, 2017, 06:19:11 pm »
Alex,
Don't lose heart on this.  It's a discussion and whether everyone agrees or not with a particular viewpoint I think we might be making some progress on what is a tough and often debated subject.  I'm not even sure I can fully state what the debate is about but somewhere near the center of the debate is a question regarding hifi equipment that deals with what can be heard and what can be measured.
Unfortunately, the issue sometimes turns a little contentious as some people dig in and then once they are certain of their position rather than playing nicely some folks resort to personal attacks.  It's a fine line from a bit of humor to making someone feel bad.  In my opinion the term "audiofool" (or however it's spelled officially) is kind of derogatory, but since I'm probably in that camp to some extent I'll suck it up and deal with it without getting too concerned by it.
I think like you / as you have expressed - that people can get to a point in a discussion where logic strongly defends a position but if the logic is based on faulty input, or incomplete input, the output can be faulty.  I tried to make a case that said 500 years ago many people were very sure that the Earth was the center of the Universe, in part because we didn't have the knowledge and science to mathematically prove otherwise with a sufficiently demonstrable line of reasoning.  For sure, when it comes to witch hunts we can burn witches at the stake over and over thereby proving that witches burn.
Lightening up the subject a bit, here is where I think we (some of us) left off.  It is from retrolefty's summary:
Electro-mechanical devices (mics, speakers, turntable cartridges) may indeed be discernible depending on the specific devices being compared.  If so it can also be measured, and if not, can be proven so via well designed double blind testing.  Anything else is just human faith based imagination.
While I believe, like you (I think), that this forum has a near religion-like belief in the infallibility of DBTs I think it was refreshing (to at least a degree) that we got to retrolefty's summary (which I think is a fine summary) because it at least leaves open the idea that different transducer designs (speakers, mics, cartridges, etc.) with mechanical components in audio systems can provide discernible audible differences.  Up to that point I was starting to think that the prevailing thought here is that little or nothing of value is discernible by human hearing.  I was starting to think that the alternative to an audiofool was an engineer who sat in his hifi room but who never actually listened to his hifi; rather his use of the hifi was strictly as a DUT that provided a reason to measure things.  In this stereo-(pun intended)-typical view, the anti-audiofool derives 100% of his enjoyment from watching numerical, graphical, and other readouts of measurements and 0% of his enjoyment is derived from actually listening to music.  Or if the anti-audiofool is not fully science oriented in their hifi endeavors they might occasionally listen to their hifi but have no sense what sounded "good" because there would be no reason to listen critically as long as the spec sheets and measurements show good numbers.  All of this is of course a bit sarcastic but hopefully not too derogatory coming back the other direction.
My more sincere view is that the science oriented audio enthusiast relies extensively if not exclusively on specifications and measurements to help select, build, and install good sounding equipment at reasonable prices so as to in turn be able to enjoy listening to music.
Where we are in this thread is that we seem to have reached a consensus (but probably not unanimity) that people can hear the differences in transducers and that those differences have measurable explanations.  We even went a step further (at least in retrolefty's summary) and said that if the differences couldn't be measured but they could be shown to exist with DBTs then perhaps some differences could be accepted as humanly discernible even if we have not yet come up with a way to explain the differences with test equipment of some sort.  To me, this is progress.
Next we get to your subject:  the amplifier.  Fwiw, I'm with you.  I think the current consensus in this forum is a bit dogmatic when we say that everything that needs to be solved with amplifiers has been solved.  I'm not saying some amplifiers haven't reached a tremendous state of performance (ie, to a very high degree they amplify the signal faithfully without adding or subtracting anything) but I don't believe this is as widely true of amplifiers as some folks might think or want to believe.  Having said that, I do think that making an amplifier go reasonably flat (say +/-0.25dB) from 1Hz to 100kHz is probably "easier" than making speakers that go from say 20Hz to 20kHz +/-3dB.  And I think it is the relatively simple frequency response measurement (combined with perhaps a few other relatively simple measurements) that cause most people to hold firmly to the notion that speakers (and perhaps other transducers) are relatively "hard" to design and build, and amplifiers are relatively "easy" to design and build.
Before we go further on the seemingly contentious subject of amplifiers, I think it might be good to look at the “half-full” side of the discussion, ie the notion that at least some hifi performance can be determined by human hearing.  Again, I am heartened by retrolefty’s summary as it acknowledges more belief in human hearing than I thought might prevail around here.
One of the biggest breakthroughs in this thread (for me) was the seeming acknowledgement that “imaging” is a real concept.  Even our forum buddy Fungus seems not only ready to get behind the concept of imaging but he seemed to put it forward as one of the key determinants of an “ideal” system (along with bass response).  Prior to this thread I would have bet that the scientifically correct hifi enthusiasts here would have dismissed imaging as an audiofool’s errand.  So I was delighted to see that imaging is an accepted attribute.
What is imaging?  Well, I couldn’t get Fungus to define it but here’s my attempt at describing it with an example.  I think imaging is the notion that when you go to see (and hopefully listen to and not just measure) a jazz band in a night club you might have the piano in one place on the stage, the bass in another location, and the drums in yet another location (since they can’t all occupy the exact same physical location).  Back in the early 1960s these types of bands were popular and they sometimes played in night clubs.  In the night clubs people in the audience sat at tables having drinks as they listened (but probably didn’t measure).  During these times a really good band with a record deal might have recorded some of their performances “live”.  In the process a sound technician might have deployed two microphones (one relatively left and one relatively right) which enabled making a two track (stereo) tape recording and ultimately a LP stereo record.  The microphones would have picked up the sounds of all the instruments and also other sounds – such as the people in the audience speaking, clapping, or maybe occasionally clinking their drinking glasses.
After the performance the recording would have been “mixed” by someone in a studio (perhaps in a team effort by sound technicians and maybe/probably with input from the band members).  Here the band team would be relying on memories, impressions, preferences, and other subjective human input to determine how much of what was actually recorded on the tape during the live performance should be retained exactly as it was captured on the tape, and how much might be subject to editing.  Perhaps the bass player wanted to hear more of the bass on the final version of the upcoming record, or perhaps maybe the band wanted to turn up the clink of a glass to help listeners get the sense of being in a night club.
The point is that with just two tracks (stereo) lots of sounds from various directions – not only left and right but also front and back were captured and transferred from the microphones to the tape to the record.  All of this results in the capture of sonic location “imaging” information – right to left and front to back.  When you listen to a good pressing of a Bill Evans record listen for the sonic image, ie the relative locations of the instruments and other sounds.  Depending on your hifi setup you might be pleasantly surprised at what you hear.  If you are really into it, try moving your speakers a few feet or inches to see if the location of any of the sounds move as a result.  (In general, but not always, try making the distance between your speakers roughly the same as the distance from the plane of the speakers to your listening position.)
Now, how does the information on the record get played back by speakers in a room?  Setting aside the “easy” amplifier, the speakers have to somehow convert electrical signals to mechanical motions and create acoustic energy that somehow conveys the “image”.  In order for this to happen with “fidelity” (faithfulness to the original – as it was captured live and then mixed with “artistic” as well as engineering input), the speakers must be able to move air in a way that creates not only the frequencies (lows, mids, highs) but also the spatial imaging (left, right, front, and back) of the individual sounds, all while retaining the subtle details of the “original” sound which means that not only do the frequencies need to sound like they did, and in their respective locations, but with the same relative strengths (amplitudes) so that some sounds aren’t emphasized more than what was originally intended and so that some sounds some aren’t deemphasized more than intended.  Why would some sound be emphasized or deemphasized?  Well, consider our speakers working hard to be “flat”.  If the speakers, for example, produce a 3dB hump at 100Hz, the sounds at 100Hz will come across significantly louder than intended by the original.  Now do the speakers do all this by themselves?  No, they do this depending on their own performance plus how they couple to acoustics of the room.  Depending on the size, shape, and surface treatments of the room, the room is very likely to either emphasize (reflect) or deemphasize (absorb) some frequencies at the expense of others.  So unless the room is designed (probably with lots of calculations when it was constructed) and then measured and treated (after it was constructed) with a knowledge of what speakers would be placed where in the room (and where relative to the listener), all of these acoustic variables could result in almost any sonic end result.  This is why sometimes speakers (and overall systems) sound one way in a showroom and then sound noticeably different when installed at home in a different room.
So, back to Fungus’ post about bass response, one of the things we find is that given the wavelength of a low note, some bass notes might be longer than the length of a person’s home listening room.  (A low note in “natural” music, for example, might be created by a 32Hz organ pedal).  If the speaker is even able to go down to 32Hz on it’s own (sans room) at 0db (ie, “flat) – and most speakers can’t – then when we put that speaker in a room that is say only 18 feet long (ie, deep front to back) the 32Hz bass note is going to hit the back wall before fully completing a wavelength and then reflect back toward the front wall (never mind anything it hits in between), and so on and so forth.  (I think a 32Hz audio signal has a full wavelength of approximately 35 feet).  Meanwhile all the other frequencies are also going to be reflected or absorbed based on the size, shape, and treatments of the room surfaces.  (These timing differences can be further exacerbated by any delay in speaker crossovers and/or the placement of individual drivers relative to the plane of the speaker.)  These interactions are going to have a significant effect on the overall sound.
Now, back to imaging.  Imaging is the is concept that if things were well recorded in the first place – with attention given to details – and if the details could be accurately retrieved from the recording (we have only touched upon the role of a stylus, cartridge, tone arm, and turntable) and if those details were transduced from the mechanical realm of the record to the magnetic and electrical realms of the cartridge while being mechanically supported properly by the tonearm and turntable and if the phono section of the preamplifier and the rest of the preamplifier faithfully amplified the phono signal before passing it to the power amplifier, which in turn faithfully amplified the signal into the speakers (we haven’t really gone very deep into speaker loads), and if the speakers were designed and built properly, and if the speakers were installed in the right locations in a properly designed room – well then, we might just have faithfully reproduced the spatial image as it was intended.
When we say we passed the signal from here (say the preamp) to there (say the power amp), we are just using brevity.  In reality, the “signal” is a composition of all the many signals (as represented by the frequencies, amplitudes, and phases) that were captured way back at the night club.
So, what should we know about imaging?  It’s a real thing and it’s filled with subtleties that once you experience it and know what you are listening for, it can make a big impact on your ears and your mind.  Most of us know imaging left to right (as a stereo image) and many of us know imaging front to back, although I think most people think of imaging in a fairly gross (large) manner – perhaps as we know it from the THX signature sound as it blares and rumbles through a commercial or home theater.  While the sound of a jet plane or a train can be very exhilarating, the same concepts of left to right and front to back can also be exciting in a more delicate and subtle way with the clink of a glass on a Bill Evans live night club recording.
So, what does this have to do with say an “easy” amplifier?  (Btw, this is where I get called out as an audiofool.)  I would like to know which measurement on an amplifier spec sheet is the measurement that tells just how accurately the “easy” amplifier reproduces the sonic image.  I have yet to see this spec on any spec sheet.  Now before someone jumps in and says “well, but if we measured frequency response, and if we did this phase test, and we applied these rigorous test procedures, etc, etc, etc. we could show just how well an amplifier handles imaging”.  To which I would say, maybe so, but a) I don’t see such tests being done and reported, and b) I bet things like the transformer(s), capacitors, and a variety of other components and circuits will have an impact on just how well aligned the amplifier output - with all the micro signals that make the composite signal input - retains the fidelity of all those details.  Further, while imaging is an attribute that took several paragraphs to describe, I’m betting there other some other sonic “attributes” that could, with further description and discussion, also be surfaced as potentially present and discernible, albeit subtle - and that often go unmeasured.
Next, we get to:  what can people hear?  My guess is that people as a species have similar hearing capabilities but within the species we as individuals have a fairly wide distribution of hearing capabilities.  What we can hear is of course in many respects measurable (frequency response, etc.).  But what we can perceive and recognize is perhaps a function of our learned experiences.  Some people can listen to music and say “that was a C note” while others have no clue, or at least they have no way to accurately express what they heard.  The point here is that just because some people can discern this, that, or the next thing doesn’t mean another person has the same capabilities.  Hearing is a function of anatomy, but also training/learning.  Likewise, the ability to express what is heard is also a skill.
In summary, I’m happy to “hear” (pun intended) that we could at least get to a consensus on retrolefty’s axiom.  While it might leave some folks thinking that the axiom should have been extended to strictly electrical components such as amplifiers, at least it seems to have opened our thinking about what causes what and how the causes and effects might be expressed in both what we can measure and what we can hear (and in turn, attempt to describe).
PS, I’m really not trying to create a battle here – just trying to express some thoughts that lead to constructive discussion and possibly some learning for everyone, me included. :) Peace. EF
« Last Edit: November 05, 2017, 06:48:08 pm by Electro Fan »
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #214 on: November 05, 2017, 06:50:38 pm »
I normally avoid posting on audio/HIFI/audiophool threads.
I am fairly literate in electronics, I do appreciate music and I have a wide range of musical taste. Yet, I consider myself a normal person, a bit on the skeptical and realist side.
While I do agree that there is a lot of audiophooling in the market, from special cables to power filters, etc., I challenge anyone to actually spend a few hours listining to a propper high end audiophile class setup.
I have had the pleasure to do so and actually have a friend who designs and manufactures such audiophile amplifiers, mostly valve based.
Never had I listened to music like that. The sound can be described as totally transparent, like when you look through a fogged glass (bad audio system) and then suddenly this glass is replaced by a crystal clear and clean glass. Also, it is amazing to close your eyes and feel the musicians located around you. It's like they are playing right in front of you, you can accustically locate them, feel them.
All this is a totally subjective feeling and it definitly does not happen with:
- cheap/bad quality setup (amplifier, speakers and source)
- bad arranged speakers
- room with bad accoustics
- source with bad recording/mastering
Regarding "cheap setup", mind you, the best cheap amplifiers can be bought on eBay: look for premium amplifiers from the early 80ies! This is what I have now...
I dare to say, that since the 70/80ies, people have lost the drive to hear HIFI quality music - they prefer to listen to their favorite songs through convinient means (phone, mp3, internet streaming), at the cost of sound quality. It's an option.
So, before engineers start to claim EVERYTHING as audiophooling, please do ask some friend or store to give you a propper listening session. Take your favorite CD's with you and just listen to them. Be open minded to listen to their suggested CD's, which have been selected based on the quality they were produced. One great CD for this is the Dark Side of The Moon by Pink Floyd. Another popular CD to evaluate a HIFI setup is "Arne Domnerus Group - Jazz at the Pawnshop".
I am pretty sure, you cannot just scientifically measure the quality of an amplifier, when it comes to reproducing music.
For example, I had a comparitive test, where the same amplifier was driving three different pairs of speaker. All of them premium audiophile ones. And I definitly like the sound of one particular set of speakers more than the other two. But the host prefered a different speaker and he was far more literate than I am. Conclusion: in the end, it is the individual taste.
After such audiophile listening session, I went back to my regular stereo set and noticed how bad it actually sounds...
After some months, I don't notice that anymore, as I am used to it again.
Chers,
Vitor
Offline Cliff Matthews
    • General Repair and Support
« Reply #215 on: November 05, 2017, 07:19:13 pm »
Thanks, so nothing remarkable for the future of PWM then. Yeah, I thought it was strange that Levinson compared their stuff to a signal coming from a 100khz system..  According to Elliot Sound Products, that's the lower-end of where PWM starts, so yeah, there's a few more harmonics down there. http://sound.whsites.net/articles/pwm.htm
Online Fungus
« Reply #216 on: November 05, 2017, 08:27:13 pm »
What's your point, exactly?
Online Fungus
« Reply #217 on: November 05, 2017, 08:35:52 pm »
Let's put it another way: Do you think amplifiers are going to get much better in the future?
Right.
Because current "spec sheets" are written by marketers and the numbers you see were chosen in the 1960s. Marketers have no interest whatsoever in providing accurate information or allowing people to easily compare their amplifiers to other brands.
« Last Edit: November 05, 2017, 08:42:38 pm by Fungus »
Online Alex Nikitin
    • A.N.T. Audio
« Reply #218 on: November 05, 2017, 08:37:09 pm »
Alex,
Thank you. I am on Internet forums from about 1994 (ever heard of Canopus?) ;) .
Cheers
Alex
Online Fungus
« Reply #219 on: November 05, 2017, 08:40:45 pm »
Huh? To reach that conclusion wouldn't you have to listen to three different amplifiers driving the same speakers?  :-//
A lot of it is also practice. You can learn what to listen for. A lot of systems might sound impressive initially but if you know what to listen for you can hear that the trumpeter at the back is a bit muted compared to other systems.
« Last Edit: November 05, 2017, 08:44:35 pm by Fungus »
Online Fungus
« Reply #220 on: November 05, 2017, 08:50:49 pm »
Yes, but some of us have been doing that since the 1980s. The sound honestly hasn't got an order of magnitude better since then, and most of the advances are in speakers AFAICT.
There you go. You're proving my point.
Modern amplifiers are smaller and more integrated but they're not particularly better.
Offline hamster_nz
« Reply #221 on: November 05, 2017, 08:55:27 pm »
I dropped out of HiFi when life changed in my mid/late 20s, and then went back in with DIY projects like home made subs and home made 300W power amps, and designed and built bi-amped active speakers using good kitset amp modules. These all worked fine (not great, just fine), but eventually I moved on to other things.
For imaging speaker placement & room layout was everything. Fire the sound across the short side of the room (helping to avoid early reflections from the walls), any my rear ported speakers need to be away from the wall by ~40cm.  However, this is now completely impractical now unless I am home alone - the main living area is ~5m x 12m, with lots of hard flooring and windows & doors down one of the  long side - you can clap and hear the reverb time, and the room just 'eats up' sound. So I've abandoned all hope of HiFi - I'm happy just to have some speakers back in the house after languishing in the garage at our old house for 10 years due to lack of room.
Offline _Wim_
« Reply #222 on: November 05, 2017, 09:27:42 pm »
But if we cannot hear the differences with exaggerated distortion in this ABX test, why would I then here the difference when just listening to music?
Would in your opinion a better test then be to use the same VST-plugin in the audio chain just listening to music, and one day listening with 0.1% of added distortion, and the next day without? Do you think the sensitivity would be increased then? As my music source is pc based and has a convolver plugin, I could easily do that also.
I would measure both power rails. If they behave the same (no big sagging), the sound will be the same also. If not, I would expect to see a difference in distortion using burst signals.
Offline Zero999
  • 0999
« Reply #223 on: November 05, 2017, 09:35:05 pm »
I don't think anyone here has referred to imaging as audiophoolery. It's perfectly rational and logical. I've listened to the same track but mixed differently and have preffered one mix, over the other. No I didn't do a double blind test on myself, so I am open to the possibility that I may not be able to distinguish between the two, although the differences seemed clear, at the time.
The point made by many people here is that a well designed amplifier has very little impact on the sound, compared to the recording, mixing and playback, from the speakers to the room acoustics. The same could be said for a video amplifier, in an old analogue TV: the camera used to record the content, the stage lighting, interference picked up by the signal as it was transmitted through the air, the quality of the CRT and room lighting had more of an impact on the quality of the image, than the video amplifier.
Offline fonograph
  • Country: at
« Reply #224 on: November 05, 2017, 10:44:37 pm »
Placebo is one hell of a drug.
