Author Topic: What makes a high end audio amp "better" then a low end unit?  (Read 59622 times)
Offline Electro Fan
Re: What makes a high end audio amp "better" then a low end unit?
« Reply #175 on: November 04, 2017, 05:43:53 pm »
I have always wanted to make my own amp that was compareable to a macintosh amp for a fraction of the price but what exactly makes it better? Lets ignore the warm harmonics the tube produce to make a better sound for simplicity so not get into the tube/solid state which is better debate.
I know amps can be graded by their THD to give you a rough idea: For instance a shit sony or equivalent will have a THD of 0.8% while a harmon kardon in that power range will be around 0.08% and a Marantz will be around 0.03%. Not that this is the answer to good sound you can hear the difference in a sony and a better amp.
So to get the best sound: Is it just a matter of hand selecting all the parts so the values are as close to design spec as possible? This would make sense why a cheap amp would sound worse because they can just buy 5% components and use them all where as higher end starts with a lower tolerance and then will hand pick them. Also would matching parts: LR channel transistors that are very close also play a big part?
So if my understanding is correct you could take an amp that has a good circuit design (are almost all of them mathematically the best we can do since its really a simple circuit that's been improved over 100 years) and then hand selected the best/matched parts;IE buying 100 resistors and discarding 99% of them could you turn the cheap sony amp into a good one? Perhaps also over sizing filter caps/ over specing parts to run at less load etc.
Hi Beamin,
Congrats on starting a stimulating thread.
I can't answer your questions definitively but here are some comments and suggestions.
First, your point about solid state vs. tube electronics is insightful - this topic alone is likely to stimulate some debate - but if you are really in search of what makes a Macintosh amplifier sound "better" (your word, not mine), perhaps you should keep your inquiry open to examining both solid state and tube amplifiers.
Next, with respect to a "$#*!" Sony, I would say that it's a bit of a harsh comment on Sony.  While Sony has over the years produced many relatively entry level (inexpensive) amplifiers, receivers, and other stereo equipment Sony was for a number of years pretty competitive in stereo equipment design.  In the 1970s they had a model called the STR-7065 that rivaled the Marantz 2270 (generally a very well regarded receiver).  The 7065 held it's own in parts, specs, and sound against the 2270 in the power amplifier section as well as in the pre-amplifier and tuner sections.
Marantz 2270
70 watts per channel RMS 20-20kHz into 8 Ohms
Harmonic Distortion 0.3%
IM Distortion 0.3%
Sony 7065
60 watts per channel RMS 20-20kHz into 8 Ohms
Harmonic Distortion 0.2%
IM Distortion 0.2%
Regardless, let's take your question about replacing the parts on a "$#*!" amplifier.  Maybe as an experiment you could select whatever you consider to be a "$#*!" amplifier and replace the parts with better quality parts, ie, parts that perform similar functions but with better values, ie, better individual measurable performance at the component level.  The idea would be to retain the same basic circuit but see if the circuit once enhanced with better parts delivers better performance.  Now we are down to the question of “What is better performance?”  Is better performance something that can be measured (Harmonic Distortion, etc.)?  Or is better performance something that can be heard?  Or both?  Is there really a measurement for everything we can perceive with our hearing?  Who knows?
Maybe you could give it a try and let us know what you determine with your measurements and listening.
Next we have the notion that the amplifier is just a "really a simple circuit that's been improved over 100 years".  100 years is a fairly long time (one human lifetime or more in most cases) and the last 100 years have been subject to considerable developments in knowledge and technology, with technology accelerating our understanding of what causes what.  The point here is that now, after 100 years, perhaps there is more than one simple circuit design for amplifiers.  Toward this end, a second experiment might include studying the designs (including the parts and their specs, and the overall circuits and circuit performance) for some of the popular and/or more well regarded amplifiers over say the last 50 years - perhaps since the 1970s or so.  You could look at the solid state designs from Phase Linear, Crown, Marantz, and others to see if you notice any differences in the designs.  Likewise, you could look at tube amplifiers from Macintosh, Audio Research, VTL, and others to see if you notice any difference in the designs.  These would be more expensive to obtain and certainly more expensive to surgically adjust with different parts so this part of the experimental process might require more study than hands-on work, but I bet if you look across the spectrum of amplifiers you will find that in both solid state and tube amplifiers there are actually quite a few different designs.  Perhaps they all came from the same amplifier tree 100 years ago and perhaps they all have a common goal of amplifying a relatively small signal from a pre-amplifier and forwarding the larger amplified signal to speakers but I think you will find considerable differences in design.  Even the most ardent, “science is science and not audiofoolery” members of this forum would have to recognize that there are quite a few different designs in the world of amplifiers. Class A, Class B, Class AB, Class D and more – especially when you consider both solid state and tube, not to mention analog vs. digital.
If you listened, could you hear any differences between the various designs?  This has become a key subject of the firestorm of a debate your post has kicked off.  I'm not ready to go there just yet, but here are some other considerations.
When we say "so to get to the best sound" (again your words, not mine) are we talking about some type of test tone or tones fed into the amplifier with an objective of determining the best sound exiting the amplifier?  Or are we talking about the best sound after real music has left the amplifier and passed through the speakers into a room in which the speakers reside?  How much consideration are we giving to the complexities of harmonics and any other interactions among all the sounds that occur in real music?  And are we giving any consideration to these signals as they entered the amplifier?  From what preamplifier was the music delivered?  And perhaps even more importantly, from what source was the signal delivered to the preamplifier?  For example, if it started as a signal embedded in a record (ie, as complex music etched into vinyl), how were these signals captured (recorded) before the record was cut?  Setting aside the microphone or microphones that were used to record the signal(s), or the acoustics of the performance that was recorded, or the performance of the tape recorder, or the skill of the sound technician that did the recording used to make the record, was the stylus that was used to retrieve the mono or stereo signals from the record part of a ceramic cartridge, or a magnetic cartridge, or a moving coil cartridge?  And what tone arm with what mass, what anti-skate, and what alignment geometry on what turntable with what suspension was used to hold the cartridge and stylus with the proper force so that the signal or signals could be retrieved from the record?
I know, none of that is what you asked about.  But at the end of the day, the amplifier is just one part of a larger chain - and it's somewhere in the middle to the back half of the chain.  Most people here would say a power amplifier has relatively little impact on the overall sound - at least compared to the impact of the quality of the recording and the playback components which required acoustic and mechanical vibrations to be converted to electrical energy and compared to the impact of the quality of the back end components (the speakers) that convert electrical to mechanical and acoustic energy.  The job of the amplifier is to amplify the signal, not add anything and not subtract or change anything.  While in some important respects a power amplifier has among the easiest of the jobs in the chain it is important to remember that amplifying test tones might be somewhat easier than amplifying complex music filled with subtleties.
Next, speaking of the speakers - this is where amplifier design can and should vary, ie, with consideration given to the speakers that will be driven by the amplifier.  For example, if the amplifier will be driving very efficient horn speakers (think Klipschorn), the amplifier might need relatively little power output - perhaps a couple or a few watts from perhaps a 45 or 2A3 Single Ended Triode tube amplifier.  On the other hand, some inefficient speakers might need a couple or a few hundred watts from a pentode tube amplifier or a solid state amplifier.  To design an amplifier to sound "good" we need to have some idea of the load - which means we need to have some idea of the speaker design.
The selection of the speakers can't be done in a vacuum (no pun intended) either because the speakers need to be placed properly with respect to room acoustics, ie, room shape, room size (how much air needs to be moved to achieve what Sound Pressure Level), and room surface treatments.  There is a reason why symphony halls have the shapes and materials they have.
Now, back to the original question, what makes an amplifier sound the way it does?  It comes down to the design including the execution of the design (ie, including the parts and the craftsmanship/quality control of the manufacturing process).  Will the differences in the design and execution be measurable?  With a part change here or there perhaps.  Will the differences between fundamentally different designs be measurable?  Probably, but it might depend on the measurement equipment and skill being applied.  Will any of these differences be audible?  Perhaps, but it might depend to some extent on all the other variables in the system from signal recording and retrieval (cartridge and tone arm) to especially the particular speakers and especially the particular room that acoustically mates with the speakers.
Net, net:  Changing some parts in a given amplifier design and then measuring and listening might be a worthwhile experiment if this line of inquiry intrigues you.  Likewise, if you have the opportunity, you might measure and listen to disparate amplifier designs and see what you determine, especially as those designs are embedded in various systems and rooms.  My guess is that changing a few parts for similar but better values will be time consuming and tedious with minimal differences in overall amplifier output measurements and the differences if any will be very difficult to hear since by the time you take the amplifier apart and put it back together with different parts your mind will not be able to distinctly remember what it previously heard.  Most A-B comparisons need to be instantaneous at the same volume levels in order to have a decent chance of revealing differences.  On the other hand, putting fundamentally different amplifier designs into otherwise same systems and rooms will very possibly reveal some different overall sounds as well as some different amplifier measurements.  Likewise, moving the same amplifier into different systems and rooms might also reveal some different overall sounds.
What causes what in sound systems is a complex issue and developing a vocabulary that accurately and effectively conveys all the possible combinations of design, measuring, and listening can add a layer of complexity and confusion that is more likely to stimulate debates than agreement unless people develop some common goals, in which case the debates can sometimes be methodically narrowed down so as to isolate some areas of agreement about what causes what.
Let us know what you determine if you make such measurement and listening tests.
« Last Edit: November 04, 2017, 06:16:15 pm by Electro Fan »
Offline hamster_nz
« Reply #176 on: November 04, 2017, 06:18:22 pm »
The HiFi purest's dream dream of "truly lifelike" sound is an interesting one... put your headphones on (or semi-decent speakers) and have listen to an acoustic guitar microphone shootout:
Even on no-so-hi-fi YouTube the different mics sound very different. Everything has already been quite significantly 'colored' at the first step of the recording process....
Offline Electro Fan
« Reply #177 on: November 04, 2017, 08:15:42 pm »
Here is an interesting Q&A regarding the guitar post from the comments sections of the post:
OnSugarHill
To the creator of this video... We can all hear these great mics and make an opinion on which sounds best. However, you are the only one who knows how that guitar sounded in that room while you were recording. Which one do you feel most accurately represents the sound in the room??
Reply
Augminished Studio
I didn't want to put my opinion in the video as I did not want any form of bias. But I was partial to the MBH 603. The 121 would be cool depending on the track. The U87 was the most "true".
This gets at the questions of what is "better" sound or what is "the best" sound.
Perhaps some people in this forum will say that none of the sounds from any of those microphones sounded different than any of the others.  These people will say that the sounds heard were all just electronically recorded and played back and any differences heard would have to be considered audiofoolery, unless the differences could be pointed out consistently in double blind tests.
Next we would have some people who would say they could hear differences but there might be some disagreement about which differences were better or best.  Or perhaps someone might point out that we are all probably listening with different amplifiers and different speakers in different rooms.  And no doubt we would have disagreement about whether the amplifier in our playback systems had any impact on the overall sound.
In my opinion, which is worth what everyone is paying for it (that would of course be zero), a good objective for a hifi system is to play back music as close to what it sounded like when it was created by the original musicians.  This is in fact the definition of "hifi", ie to retain a high degree of fidelity to the original.  But even this is difficult to know unless we were present to measure and/or listen to the original when it was recorded.
In the case of the youtube video creator he apparently thought one of the mics best captured the "true" sound of the guitar as it originally sounded, but that of course was based on the system (including the amplifier and speakers) he listened to when he played the recording (possibly in the same room as was used for the live guitar music - so the same room acoustics).  Most likely his preference was based on his subjective opinion unless he "measured" the fidelity of the mic'd recording by comparing the measured recording to a measurement of the original music.  (Not sure what single measurement or few measurements would capture all the subtleties that the ear can hear.)  Further, even though he thought one mic was more "true" than the others, he had a preference for yet another mic.
There are LOTS of variables at work:  1) some that are objective, easy to isolate and easy to measure; 2) others that are objective but harder to control and measure; and 3) some that are subjective.  All of which can be somewhat hard to convey with words as words often have different meanings to different people.  Which is probably why some people find supreme comfort in numbers :)
My overall opinions are that 1) different electronics will likely measure different and are sometimes audibly discernibly different, 2) not everything that is audibly discernibly different is readily measureable in the electronics, 3) we all vary in our abilities to hear (this can be measured in various manners), and 4) we vary in our preferences regarding what is good, better, and the best sound.
Online Zero999
  • 0999
« Reply #178 on: November 04, 2017, 09:26:39 pm »
So what do you want from your amplifier?
How much power does it need to output, into what load impedance? That will determine the supply voltage, current, along with the components used. VPEAK = (PRMS×2RL)0.5 To avoid distortion, the supply voltage should always be a higher than the voltage drop of the output stage, plus a bit of headroom.
What do you mean by sound good?
If you mean not distort, or colour the sound, in any way detectable to the human ear, i.e. be audibly transparent, then that's fairly easy to achieve, at a fairly low cost, with modern discrete components and amplifier ICs. The most important thing is not to allow the output voltage to go anywhere near the point where clipping occurs. This is normally fairly easy to detect by listening to it, but basic VU meter which flashes a red light, when the output is clipping and another light, when the output is near-clipping, is a very good idea. The next thing is to ensure the IC or transistor output stage, is kept cool enough to avoid overheating or any thermal protection circuitry from kicking in and distorting the sound. That's relatively easy to do for modest power ratings (under a few hundred Watts), given that the average power dissipation is usually a fraction of the peak power output.
If you want some level of distortion, then that becomes more tricky, because you need to know what sort of distortion you like. There's the world of valve amplifiers and digital processing, which attempts to emulate different valve amplifiers. I admit I can't be much help with that, as I like amplifiers which don't introduce any distortion. The main market for distorting amplifiers are musicians, who want their instruments and often vocals to be coloured by the valve sound of the 50s and 60s.
Anything you build will work out more expensive than modern, massed produced equipment, but it will still be cheaper than high end, possibly audiophool equipment. Other than the fun and educational element, the main advantage of building your own, is you know how it will perform, especially if you use a decent, genuine audio amplifier IC, with a proper data sheet and figures to back it up, or a tried and tested design, again with all the test data to back it up.
Offline fonograph
  • Country: at
« Reply #179 on: November 04, 2017, 10:00:59 pm »
Double blind test is to audiophool what sunshine is to mold.
The following users thanked this post: george.b
Offline Fungus
« Reply #180 on: November 04, 2017, 10:11:26 pm »
Nope.
I bet there's not a single one.
It's obvious that anything with mechanical parts can influence sound, that some will be better than others.
Offline Electro Fan
« Reply #181 on: November 04, 2017, 10:54:10 pm »
Nope.
Cool - if you are right then we’re all in agreement that different transducer designs with mechanical components in audio systems can provide discernible audible differences.
« Last Edit: November 04, 2017, 10:55:54 pm by Electro Fan »
Online Zero999
  • 0999
« Reply #182 on: November 04, 2017, 11:04:20 pm »
Nope.
That's true and the same goes for amplifiers. The question is whether the differences are detectable by the human ear? Double blind testing is required to determine that, but it's more difficult for microphones, than for amplifiers. Unless the microphone is being used to record music played through a speaker, the musician needs to be made unaware of which microphone is being used to record them, otherwise it might influence how they play.
Offline coppice
« Reply #183 on: November 04, 2017, 11:14:23 pm »
Of course microphones sound different, and often blatantly obviously different. Although microphones generally fall into patterns of response, like cardioid, no two models of mike have exactly the same spatial response pattern. That means the mix of direct and indirect (reflected) sound being picked up by the mics differs. Resonances, the difficulty of placing two mics in the same place (as you don't know exactly where its effective centre is), and other mechanical factors also change what is picked up.
Online Zero999
  • 0999
« Reply #184 on: November 04, 2017, 11:38:25 pm »
Yes that's true. I think I missed the point before. The differences between good microphone designs is greater than amplifiers and this intentional.
Offline retrolefty
« Reply #185 on: November 05, 2017, 01:11:16 am »
Nope.
 Electro-mechanical devices (mics, speakers, turntable cartridges) may indeed be discernible depending on the specific devices being compared.  If so it can also be measured, and if not, can be proven so via well designed double blind testing. Anything this else is just human faith based imagination.
Offline Electro Fan
« Reply #186 on: November 05, 2017, 02:49:07 am »
Nope.
Seems like a fine summary.
Offline hamster_nz
« Reply #187 on: November 05, 2017, 05:06:53 am »
No, I think it is worse than that.
You can't achieve "transparent" HiFi (HiFi that is like being there)... Even for purely acoustic recordings the recording has already been shaped by the recording process - the venue, choice of mics, the placement of mics, the mixing of mics, the recording desk used, the mastering process and so on... even before the listener gets their hands on it.
To jump analogies, Highend HiFi is like arguing which camera gives the most realistic image of a "landscape" when you take a photo of an oil painting. A crappy camera is easy for all to see, but between reasonably good cameras it is subjective - "Fuji has deeper greens making the grass look better", "Cannon has more muted blues, making the sky look better", "but Nikon has beast flesh tones, making the people more realistic (even though there are no flesh tones in a landscape)" - all this when looking at photos of a painting, which is already an artistic impression of what the landscape looked like.
« Reply #188 on: November 05, 2017, 05:33:14 am »
HIFi is a subjective thing, generally to me anything over 320k MP3 is as good as the CD, as I cannot hear the difference at 256k MP3, using the equipment I have. All else is merely just you believing things are better, and past a certain point all will behave pretty much the same. All that we can agree to is that a small speaker out of some random low cost manufacturer, where QC is the guy next door, will sound bad when paired with an amplifier made from whatever parts were cheap that day.
In any case with speakers the most important part is the magnet, basket and coil and core, as that is what determines how good it is. Expensive speakers often use quite cheap drivers, and generally any amplifier will drive a speaker perfectly well at low levels, which is where they will spend most of the time being used.
Online BrianHG
    • LinkedIn
« Reply #189 on: November 05, 2017, 06:43:12 am »
After all this talk about bandwidth and THD, how come all amp specs ignore full power bandwidth, IE, a 20khz spec amp which has a max power of 100watts may do well at that frequency at 10 watts but begins to distort above 50 watts at 20Khz while it can do 5KHz fine at full 100 watts.
Even more useful would be frequency phase shift at the higher frequencies at higher power levels.  I know here, with opamps at low power, 20KHz may be nothing, but, with an amp designed to drive a speaker with high voltage and current through an unpredictable cable length may already exhibit phase behavior 's at 20KHz like a good quality audio op-amp would exhibit at 1MHz domain.
__________
Follow me for 3 Classic Fitness Playlist Songs from the '70s to 2010s, Delivered Every Other Day!
www.linkedin.com/in/brianhg-ocean-fitness www.facebook.com/profile.php?id=61573174078303
Offline ruairi
« Reply #190 on: November 05, 2017, 06:57:41 am »
That spec is ignored because music does not contain anywhere near that much power at higher frequencies, it's just not how we use power amps.
Re your second point why will the phase shift at hi frequency change under normal use higher power levels?
Online BrianHG
    • LinkedIn
« Reply #191 on: November 05, 2017, 07:11:56 am »
I know higher frequencies in music have lower power levels.  I just don't an alteration in phase as I change the volume level & change the music type.
Op-amp example:  With an TLO81 opamp, I can actually get an ok 1Mhz performance with a minimal gain setting and a 1vp-p signal out, but, going up to 10vp-p, it cant quite make it there.  This may have partially a connection to the slew rate of the op-amp's output.  In a audio power amp, slew-rate can play a similar role in distorting phase at higher signal power levels at it's peak frequency output.
Remember, we are talking about the differences of what makes a good VS a bad audio amp & I think this little tid-bit is ignored.  I know the Amp I personally chose for myself is a basic, all discrete MOSFet output design which can deliver the full 100KHz at 250 watts, it can also deliver a 1MHz signal up to around 10 watts.  But, my really old equipment did much worse.
Refinement in the higher frequencies steadily deteriorated with louder volumes in my older amp.  Cymbals lost their distinct multitude of rings and were steadily changing into noise at loud volumes.  My new super fast audio amp does not exhibit this problem.
« Last Edit: November 05, 2017, 07:20:35 am by BrianHG »
__________
Offline _Wim_
« Reply #192 on: November 05, 2017, 07:24:28 am »
Why would you think this would not show up in a THD plot vs frequency. If you measure THD vs Frequency at high power you will also clearly see this effect. This is why companies like Hypex for example plot THD vs frequency at very low power, mid power and high power. In this one plot you can already see quite a lot of information.
Online BrianHG
    • LinkedIn
« Reply #193 on: November 05, 2017, 07:36:21 am »
Careful, not all audio amplifier manufacturers care to spec everything at all power levels.  We are in the realm of what makes a good VS bad amp here.  A better response would be to only select from amp manufacturers who properly plot the THD at all power levels and frequencies.  The problem here is that there may be good quality affordable designs out there which haven't gone through the trouble to do such plots while the majority of others may just be hiding nasty truths about the limitations of their design.
__________
Offline Fungus
« Reply #194 on: November 05, 2017, 07:39:04 am »
Nope.
Nope.
All speakers and microphones have to be compromises. There's no way around it.
eg. The ideal speaker would be a tiny point source of sound, but that's impossible to manufacture in practice because a speaker needs to move large amounts of air around. Real life speakers are therefore a compromise between stereo imagery and bass response. You can never have both.
This is NOT true of amplifiers. Amplifiers aren't constrained by physical properties like air movement.
« Last Edit: November 05, 2017, 07:43:28 am by Fungus »
Offline _Wim_
« Reply #195 on: November 05, 2017, 07:58:27 am »
Yes, I know detailed specs are a problem. I just wanted to respond to your quote "After all this talk about bandwidth and THD, how come all amp specs ignore full power bandwidth", becasue in my opinion this does not bring any additional values if you have THD vs power vs frequency info.
I would not say it is "additional trouble", as during the design of the amp they should have measured this anyway (how would they design for good specs otherwise?). I think the main problem with the audio business is they do not want objective criteria to compare products, because that would mean that the many small companies in this branche would not be able to survive, because it hard to explain a mass produced device costing 10 times less has the same of better specs
In one of the previous post here was written that the fact that a high quality amp could be brought to the market by a smaller company for 300£ proves that the problem was solved long ago, and I could not agree more with this statement.
The following users thanked this post: Fungus
Offline Electro Fan
« Reply #196 on: November 05, 2017, 08:47:59 am »
Nope.
Nope.
Fungus, please tell us:
1. Why is the ideal speaker a tiny point source of sound?
2. Are there any other attributes or specifications of "the ideal speaker" other than it being a "tiny point source of sound?"
3. How much air is "large amounts of air"?  Does the "ideal speaker" have a specification for moving "large amounts of air""
4. What is your definition of "stereo imagery" and how much (or what specifications) would be ideal stereo imagery?
5. What is your definition of "bass response" and how much (or what specifications) would be ideal bass response?
6. Why can no speaker ever have both ideal bass response and stereo imagery?
7. What are the best speakers you have heard in terms of bass response?
8. What are the best speakers you have heard in terms of stereo imagery?
9. What are the best speakers you have heard that make the best compromise between bass response and stereo imagery?
10. (Bonus question):  Is your favorite word "Nope"?
Thanks, EF
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #197 on: November 05, 2017, 08:53:15 am »
I'd say the ability to recreate the waveform of input in output, but amplified, is the key.
Does it output square, sine, saw tooth, of the same shape as input throughout and wider than the frequencies of hearing range or does it rounds off the edges or straightens out the curves.
Offline _Wim_
« Reply #198 on: November 05, 2017, 09:17:42 am »
Waveforms with sharp corners (square and triangle) dictate infinite frequency response if NO rounding is required. Such waveforms can be described as a sum of sinusoidal waveforms (and will "sound" like that also). The more high frequency sinusoidal waveforms you add to the sum, the sharper the corners will be.
Looking at a square waveform can be interesting (to see ringing for example) and easy to do (main advantage of square wave testing), but THD+IMD together with frequency plots will show the same information also in a way that makes it easier to compare performance ("good" square wave performance is a more subjective criteria)
Offline Fungus
« Reply #199 on: November 05, 2017, 09:23:20 am »
Simple version: A big round thing moving in and out doesn't produce as directional a sound as a smaller round thing moving in and out.
Headphones.
Nope.
« Last Edit: November 05, 2017, 09:34:19 am by Fungus »
