Author Topic: What kind of capacitors are these?  (Read 1742 times)
Offline oPossumTopic starter
« on: July 19, 2018, 04:13:40 am »
These are in a Heathkit IN-27 decade capacitance box. They have a waxy feel. Looks like a single layer dielectric - not wound. SRC may be the manufacturer - Societe de Composants Record.
What is the likely dielectric and plate material?
Offline RJFreeman
    • Australian Technical Production Services
Re: What kind of capacitors are these?
« Reply #1 on: July 19, 2018, 04:31:24 am »
My guess would be Silver Mica Capacitors
Offline +Mikie
« Reply #2 on: July 19, 2018, 11:20:51 am »
My guess would be paper capacitors. If you're interested in replacing them use either ceramic, MKT or MKP.
Z80
  • Guest
« Reply #3 on: July 19, 2018, 11:50:44 am »
I'd say they were mica caps, they look like old micas.  Being used in a substitution box they need to be accurate and stable.  I seem to remember most of the paper caps were cylindrical and as reliable as a 2 week weather forcast.
Offline vk6zgo
« Reply #4 on: July 19, 2018, 01:46:29 pm »
Mine, too!
Australian mica caps usually were coated with hard Bakelite, but those from the USA & UK often had that waxy encapsulation.
Offline HB9EVI
« Reply #5 on: July 19, 2018, 02:03:10 pm »
silver mica!
Offline David Hess
  • DavidH
« Reply #6 on: July 19, 2018, 06:14:30 pm »
The 1% tolerance, size, and form factor are enough to know that those are silver mica capacitors however in case there is any doubt, they were made by SRC (Stability Radio Components).
« Reply #7 on: July 19, 2018, 08:25:20 pm »
Wow. No doubt that is what they are. I have never seen this style of old cap before, and all the silver mica caps I have seen are the modern epoxy encapsulated style. Thanks to all who responded.
Testing with a DE-5000 suggest they are still within spec.
103.7  +3.70%
203.0  +1.50%
302.9  +0.96%
403.0  +0.75%
503.7  +0.74%
604.3  +0.72%
703.4  +0.49%
804.1  +0.51%
904.7  +0.52%
1004.7 +0.47%
1.003  +0.30%
2.009  +0.45%
3.017  +0.57%
4.006  +0.15%
5.007  +0.14%
6.015  +0.25%
7.020  +0.29%
8.021  +0.26%
9.028  +0.31%
10.026 +0.20%
10.07  +0.70%
20.12  +0.60%
29.85  -0.50%
39.75  -0.63%
49.83  -0.34%
59.87  -0.22%
69.57  -0.61%
79.69  -0.39%
89.73  -0.30%
99.79  -0.21%
Offline Gyro
« Reply #8 on: July 19, 2018, 08:46:49 pm »
Don't damage that soft wax coating (yes, it is wax) that keeps the moisture out and they should stay that way for a long time. Stability is Silver Mica's forte.
Best Regards, Chris
Offline +Mikie
« Reply #9 on: July 20, 2018, 12:34:38 am »
Yeah, my bad. Paper ones were always cilindrical, you could see the layers from the sides. It was fun unrolling them, that's about all they were good for :P
Offline David Hess
  • DavidH
« Reply #10 on: July 20, 2018, 01:47:03 am »
They did make rectangular paper capacitors as shown at the first post here for M1 and M2:
https://www.radiomuseum.org/forum/replacing_old_capacitors.html
My ESI impedance bridge uses mica capacitors are shown for M4 at the above link with the colored dots for the oscillator and filter.
