Lower leakage, and a much lower cost, plus in the most case using a TO92 package transistor, is they are insensitive to light increasing leakage current. Plus as well higher current handling capacity, unlike the low leakage diodes. As well if you run then so the emitter is the positive lead you get a poorly defined zener voltage of around 6V, but current handling equal to the transistor if there is need for it, and leakage current that i typically only available with very expensive devices. If you need lower leakage you go for junction FET's with the emitters joined together, and use the gate as low capacitance diode in the clamp, though there you will need a power supply clamp to handle the charge injected into it during clamping.
