Author Topic: What is the Formula for distance between Two Trace  (Read 9620 times)
ashish17
  • Guest
« on: December 18, 2014, 07:18:38 am »
what is  the formula for distance two trace worked on 3v3 ,one of them as signal and other is supply.
how i calculate the distance between these two trace
Offline Zero999
  • 0999
Re: What is the Formula for distance between Two Trace
« Reply #1 on: December 18, 2014, 12:04:00 pm »
There is no formula.
If you're talking about a 3.3V the creapage distance is so tiny you won't be able to get a PCB reliably manufactured which will cause any problems with creapage.
Offline KJDS
    • my website holding page
« Reply #2 on: December 18, 2014, 12:23:53 pm »
and if you want to know how much coupling there is between them, then use Hammerstad and Jansens equations.
Offline mikerj
« Reply #3 on: December 18, 2014, 12:33:27 pm »
Possibly the most vague opening post I've ever seen. |O
This might help, on the assumption you are worried about capacitive coupling
http://www.edn.com/electronics-blogs/bakers-best/4426162/PCB-signal-coupling-can-be-a-problem
ashish17
  • Guest
« Reply #4 on: December 18, 2014, 12:43:00 pm »
sir i have asked this questions in interview
Offline con-f-use
  • Country: at
« Reply #5 on: December 18, 2014, 12:47:20 pm »
 |O |O |O |O
ashish17
  • Guest
« Reply #6 on: December 18, 2014, 12:50:40 pm »
thanks for your reply.
and this is basic for mi
if i start routing 3V3 supply track and one signal track, i dont know what is the clearance between this two track.
Online wraper
  • Country: lv
« Reply #7 on: December 18, 2014, 12:51:18 pm »
:-DD  :palm:
Online wraper
  • Country: lv
« Reply #8 on: December 18, 2014, 12:57:29 pm »
Minimum your pcb manufacturer allows if you are tight in space up to infinity, there is no formula. Of course if you don't do controlled impedance, however if you do, you need to know your target impedance first of all. And then it is not just distance to nearest track, but also pcb material and thickness, layers, track width, yada yada yada.
Offline tggzzz
« Reply #9 on: December 18, 2014, 01:08:22 pm »
I hope you mean you "have been asked this question in interview".
In that case your response should have been to enquire "formula for what?", e.g. capacitance, impedance, coupling, maximum voltage, manufacturability, etc.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #10 on: December 18, 2014, 01:14:18 pm »
Quite possibly, something has been lost in translation...
Seven Transistor Labs, LLC
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #11 on: December 18, 2014, 08:23:19 pm »
Please do not post the same question three times!!!!  |O |O |O :palm: :palm: :palm:
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #12 on: December 18, 2014, 08:33:12 pm »
You can use the Saturn PCB Toolkit for all of your PCB related calculations.
http://www.saturnpcb.com/pcb_toolkit.htm
Offline dannyf
« Reply #13 on: December 18, 2014, 08:42:41 pm »
X, where x is from -infinity to +infinity.
Offline suicidaleggroll
« Reply #14 on: December 18, 2014, 09:51:21 pm »
42
Offline Simon
  • Global Moderator
« Reply #15 on: December 18, 2014, 10:02:50 pm »
How many thousands of years did that take to work out ? ;)
Offline free_electron
    • SiliconValleyGarage
« Reply #16 on: December 18, 2014, 10:09:09 pm »
inner layer / outer layer ?
humidity ?
ambient air pressure ?
covered with soldermask or open ?
what noisemargin do you have ?
what impedance is the signal supposed to see ?
what core material do you use ?
do i need to go on ?
Offline dave_k
« Reply #17 on: December 19, 2014, 03:00:07 am »
It's for same formula for working out how long is a piece of string.
x = (d/2) * 2
ie: twice the distance from one end to the middle.
« Last Edit: December 19, 2014, 03:01:44 am by dave_k »
« Reply #18 on: December 19, 2014, 03:54:42 am »
4000, of course.
Offline DavidDLC
« Reply #19 on: December 19, 2014, 04:17:47 am »
I start to dislike EEVBlog just for these type of comments your are making, the poster is trying to reach for help, maybe a problem with language ? and you come with stupid comments
Offline zapta
« Reply #20 on: December 19, 2014, 07:15:17 am »
Well said.
Offline Simon
  • Global Moderator
« Reply #21 on: December 19, 2014, 07:37:03 am »
And it gets tiring when people join who are that childish that they have to post the same topic 3 times. I think the question was adequately answered, it has already been pointed out that for 3.3V there is no minimum as it will be well under the minimum clearance distance the pcb can be made to and others have asked for more detail but no reply.
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #22 on: December 19, 2014, 06:29:53 pm »
Isn't it quite likely he doesn't realise this? I think he has so much issues with the language he does not know exactly what he is saying, nor what the replies are trying to tell him. The attitude in many of the comments won't help with that either.
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
« Reply #23 on: December 19, 2014, 08:20:55 pm »
Nothing will help with that, other than learning the language to a level at which he can form his question into a coherent sentence and understand and respond to questions presented to him.
Offline Simon
  • Global Moderator
« Reply #24 on: December 19, 2014, 10:31:53 pm »
anyone with limited english and the need to make multiple identical posts will not get far on here. For one multiple posts asking the same question will get you banned and for second whatever your first language is i bet it's not even anyone elses 2nd, 3rd, or 4th. This is an english speaking forum after all.
