Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Capacitor on output of buck led dimmer? (meanwell LDD)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Capacitor on output of buck led dimmer? (meanwell LDD) (Read 547 times)
Sounduser
Contributor
on:
May 25, 2020, 06:13:26 pm »
Hi, Is there any reason I cant put a capacitor on the output of a meanwell LDD- H led driver?
Its essentially a buck converter, controlled by a pwm signal.
The data sheet doesnt say anything.
https://www.meanwell.com/Upload/PDF/LDD-H/LDD-H-SPEC.PDF
The light makes cameras have lines on the pictures.
I tried a 4700uf capacitor on the output and the lines went away.
Any ideas?
Logged
wraper
Supporter
Country:
Re: Capacitor on output of buck led dimmer? (meanwell LDD)
Reply #1 on:
May 25, 2020, 06:20:45 pm »
If dimming is used, you shouldn't do that. If not, probably it will be OK, though 4700uF sounds troublesome during startup. And if dimming is used, you better disable dimming rather than search for troubles with capacitor.
Logged
Sounduser
Contributor
Reply #2 on:
May 25, 2020, 07:42:02 pm »
I realise 4700 is very high. I just had that to hand at the correct voltage.
I didnt think it would be a good idea. or everyone would be doing it .
Logged
langwadt
Super Contributor
Country:
Reply #3 on:
May 25, 2020, 09:23:54 pm »
front page of the datasheet: EXTERNAL CAPACITANCE LOAD (max.) 2.2uF
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
