Author Topic: What is this USB connector?  (Read 638 times)
Offline FaranightTopic starter
  • Country: si
« on: September 16, 2024, 07:47:11 am »
Hello, does anyone know what this connector is (what part number), and whether it's possible to order them from a store like Mouser? I know it's an automotive USB connector because I found it on a cable that was salvaged from a Suzuki car, and it was used to connect the car stereo with the front panel USB port. The cable itself looks like a high-quality shielded USB cable from Belden, and there are two slightly different connectors on each side (blue and brown). The blue one fits into the front USB adapter, and the brown one fits into the stereo unit.
https://simssuzukiparts.co.uk/products/new-genuine-suzuki-swift-4-pin-aux-usb-wire-cable-stereo-plug-socket-39106-68l00
Fara-day? Fara-night.
Offline jasonquin
Re: What is this USB connector?
« Reply #1 on: September 18, 2024, 05:56:27 am »
Probably this one.
Regards,
J
Online coromonadalix
« Reply #2 on: September 18, 2024, 09:43:35 pm »
yes it is usb cable,   you can do  some cheap one with 0.1" idc connector,
there was some  in nissan car too on Ali,  but the ident notch(s) near the latch and bottom where not the same, i had to do some magic
 some used them  but cutted out the usb end  to fit the pins to a new usb plug, because compatibility is not assured with suzuki
you have this cheap one too   less $$$ than suzuki  loll
https://www.aliexpress.com/i/1005003137826612.html
at this price, it's a no brainer, i paid more than that, to fit the suzuki infotainment in a 2006 2007 Grand vitara ... the main plug is ok,  but the options not
antenna is Fakra connector  code C    i think
« Last Edit: September 18, 2024, 10:24:11 pm by coromonadalix »
  • Country: si
« Reply #3 on: September 19, 2024, 09:12:44 am »
jasonquin: Oh my goodness, you're right! It is in fact GT17HN. Now that I look at it, it has this engraved on it side, and it looks exactly like the one.
And it's on Mouser, too: https://eu.mouser.com/ProductDetail/Hirose-Connector/GT17HN-4DS-5CF?qs=vnk2wBG9e15LdyjWXkZ9Nw%3D%3D
I can now order this from parts on Mouser and make my own cable assembly for a fraction of the Suzuki price (60+ EUR)!
EDIT: Connector assembly parts list:
  • GT17HNS-4DS-HU, outer enclosure, 2 pcs
  • GT17HNS-4DS-5CF, metal frame, 2 pcs
  • GT17HN-4DS-2C(A), plastic insert A-key (brown), 1 pcs
  • GT17HN-4DS-2C(C), plastic insert C-key (blue), 1 pcs
  • GT8-2428SCF(70), crimp terminals, 8 pcs
  • Belden E357312-S, USB cable, 50cm ??
« Last Edit: September 19, 2024, 03:16:13 pm by Faranight »
The following users thanked this post: jasonquin
Offline Bryn
    • mindsConnected
« Reply #4 on: September 19, 2024, 02:11:49 pm »
That's quite a pecular USB connector... never saw anything like in my life :o
mindsConnected
Alternate tech forum for all... we welcome engineers also!
Interesting long read: Create a 12v battery from 6v batteries
  • Country: si
« Reply #5 on: September 19, 2024, 03:15:35 pm »
Hmm, the original part USB cable says the following, but I can't seem to find anything with this ID on the internet:
Belden E357312-S 1PR28 2C20 SHIELDED USB2.0 5U AWM STYLE 2725 80C ...
The cable is clearly a USB cable - it has 4 wires - red, black, green and white. The power wires (red/black) are much thicker than the data ones (green/white).
The only thing that Google returns on E357312-S is some Belden CAT6 ethernet cable, but that can't be it. Maybe I can use a different cable/manufacturer in the assembly.
« Reply #6 on: September 20, 2024, 08:48:38 pm »
dont worry  any good 4 wires plus shield  is okay,  the shield is most of the time connected to ground,  unless the connector as a metal shield who covers the plug, and once connected it will be grounded
the belden E357312   specs  attached file ...  they say 5 conductors ??
1.yellow2.green 3.red 4.black 5.white
BELDEN E357312-S   5C26 AWM    STYLE 2464
80 degree C
300V VW-1 - - -  AWM I/II A/B
FT1 ROHS
« Last Edit: September 20, 2024, 08:56:18 pm by coromonadalix »
