Author Topic: Vintage RS 7 Seg PCB  (Read 861 times)
Offline SupernautTopic starter
« on: July 03, 2024, 06:22:48 pm »
I recently received a batch of vintage electronic components in a job lot, it has two of these RS 7 segment controllers but I cant find any information or pictures online. Has anyone ever dealt with one of these before? Im guessing its from the 1970's at least, would be curious to know if it could be used.
Offline jbeng
Re: Vintage RS 7 Seg PCB
« Reply #1 on: July 03, 2024, 07:18:17 pm »
Based on the components on the boards, these appear to be counter/display boards.  I can't tell by the photo what type of displays those are, but they appear to be incandescent 7-segment devices, sometimes called "Numitrons".  You should be able to see lamp-type filaments arranged in a 7-segment configuration inside the tubes to verify this.
Since the ICs are 7400-series TTL, (7490=decade counters, 7447=7-segment display drivers - 1972-73 vintage based on the device date codes) they will run on 5 volts only.  If the displays are numitron type, they will also likely run on 5 volts... more than that and you may damage the displays and/or the electronics.
"It's such a fine line between stupid and clever" - David St. Hubbins
The following users thanked this post: Supernaut
« Reply #2 on: July 03, 2024, 10:39:03 pm »
It is indeed! I just powered it with a variable power supply and kept it below 5v, sure enough it pops up with a number 6 on the valve. Ive never seen one of these before so i wasn't sure what to expect, i knew it would deal with numerical LED's but i didn't expect the valve itself to have the numbers in it.
Thanks very much for your response  :-+
Online themadhippy
« Reply #3 on: July 03, 2024, 10:45:54 pm »
Offline Kim Christensen
« Reply #4 on: July 03, 2024, 11:00:12 pm »
As is, they could be cascaded as a simple counter.
If the white jumpers were removed, the 7475 installed, then these cards could be used in a frequency counter with a bit of additional logic. Looks like they were meant to plug into a mother board as individual digits in a counter of some sort.
But it's old power hungry tech. So unless you're into the nostalgia of it, there's not much use for them.
« Last Edit: July 03, 2024, 11:01:55 pm by Kim Christensen »
Offline floobydust
« Reply #5 on: July 03, 2024, 11:26:45 pm »
What part numbers are on the display tubes?
« Reply #6 on: July 04, 2024, 12:02:33 am »
The full name/number on the glass is;
RS
7-SEG
IND
58-635-2
F7421
Thanks for the replies so far!
Online retiredfeline
« Reply #7 on: July 04, 2024, 01:40:17 am »
The 7475 is a 4 bit latch so I think that the inclusion of that will allow the counter output to be held.
« Last Edit: July 04, 2024, 01:42:10 am by retiredfeline »
Offline floobydust
« Reply #8 on: July 05, 2024, 07:23:52 pm »
Most of the date codes are 1974 and I couldn't find any RS related info.
The display tubes are RS house-numbered which seems even more rare. I thought RCA DR2100 etc. were the only players back then but the internals look different, not sure what make OP's are.
Offline CaptDon
  • Country: is
« Reply #9 on: July 07, 2024, 04:41:40 pm »
I don't remember Radio Shack having that P.C.B. available but back in their hayday they had many kits available including complete ascii keyboards and such and most of the stuff was handled also through Allied Electronics in their catalog. Radio Shack had a lot of cool stuff in the early to latte 70's. Some of the kits were digital clocks and I believe a 6 digit frequency counter using the 40 pin LSI chips. I really miss the old RS stores which were Tandy franchises. I did a lot of saddle making and repairs of the old McClelland civil war saddles for the re-enactors and I was often buying supplies at the Tandy Leather Store in Duncannon Pa. along the Susquehanna River.
Offline floobydust
« Reply #10 on: July 07, 2024, 05:24:29 pm »
It's not Radio Shack- but I think RS Electronics in the UK.
I was trying to work backwards from the display tube manufacturer, I can find only RCA did the Numitron.
If you need to cry, here's a good place https://www.radioshackcatalogs.com
Offline CaptDon
  • Country: is
« Reply #11 on: July 07, 2024, 05:43:12 pm »
Ahh, I was unfamiliar with RS Electronics from the U.K. I will look into their history.
Offline Gyro
« Reply #12 on: July 07, 2024, 05:47:40 pm »
Actually, not that power hungry for a sunlight readable display. The Minitron 3015F Numitron consumes 8mA / segment (those are probably similar), not that dissimilar from a sunlight readable LED display. Replace the 74 series chips with 74HC and they wouldn't be that bad. Those displays were used extensively in fuel pumps for their life, readability and temperature range (down to -50'C) until relatively recently. 7 segment LCDs have pretty much taken over in fuel pumps now (but they were also available back then). I would be surprised if the LCD panels don't include some low level heating even now.
Best Regards, Chris
Online factory
« Reply #13 on: July 07, 2024, 05:56:49 pm »
It's RS Components in the UK, originally known as Radiospares.
I've only got a couple of old RS catalogs, the oldest from 1984 has ready made blank PCBs for building a 8 digit LED based universal counter and many other things, someone on here might have an older catalog with information; https://www.vintage-radio.net/forum/index.php
The hard bit would be finding the RS datasheets to go with them, we had slightly more recent folders of these at work, but no-one was allowed to rescue or buy anything and they are now long gone.
Online factory
« Reply #14 on: July 07, 2024, 06:01:03 pm »
Actually some were still in use at a small independent garage near me this year, sadly the garage closed last month after the owner passed away.
Online factory
« Reply #15 on: July 07, 2024, 06:25:20 pm »
RS 58-635-2 was made in Japan, possibly by Apollo.
« Last Edit: July 07, 2024, 06:35:32 pm by factory »
Offline nfmax
« Reply #16 on: July 07, 2024, 06:34:27 pm »
I remember those! The Radiospares catalogue used to be a thin A4 magazine type thing, before growing into a phone book sized boxed set, after which it was online only. Originally, R/S sold spare parts to the radio & TV repair trade, and were very touchy about who could open an account with them, later on they opened up and now they’re a general full service broadline distributor.
The decade PCBs date to the early stages of the transition. You could make a counter using them, or most people used them to make clocks. The really adventurous could make a DVM, even!
The following users thanked this post: SeanB, Supernaut
« Reply #17 on: July 07, 2024, 06:56:05 pm »
Happy to see so many responses, got a bit more attention that i anticipated. For the curious ive taken a few backlit photos and a clear top down photo of the PCB so you can get a better idea of what's going on. I have two of these but currently no use for them so it would be interesting to know what people would do with these if they had them.
Online factory
« Reply #18 on: July 07, 2024, 06:56:22 pm »
I've only seen the decade display boards appear on their own, yet to find something that got built with them in such as a counter or DVM.
One of the other RS kit boards I remember was the 8038 based function gen board, these were used in some custom built test boxes at work, one of which had four of them.
Online themadhippy
« Reply #19 on: July 07, 2024, 07:20:30 pm »
They did have a separate company in the 70's that sold to the hobbiest,the name escapes me at the moment.
count the number of times people point at them and ask "whats that for?"
« Reply #20 on: July 07, 2024, 07:40:18 pm »
I'd probably just sell them on e-bay or something since I'd only have two digits to play with.
But, if I was into model rocketry, they might make a cool count down display for the igniter.
« Reply #21 on: July 07, 2024, 08:59:34 pm »
I only have two or three visitors to my house so i could tally that number up quite quickly  :-DD
I might sell them but the whole batch of vintage electronics only cost me £13.50 so they don't really owe me much, if i find more of them it increases my chances of building something if i just hold on to the two i have already.
Il see how it goes  :-+
