I'm working on a circuit for a project I'm in the middle of. I was instructed to put these Schottky diodes in my circuit right next to an Adafruit NeoPixel. I understand that the NeoPixel doesn't want to get a data signal when it's not powered and that these diodes are supposed to help protect it for that scenario. But I don't understand how they do anything. Relevant portion of the diagram attached. Here is what I think is going on based on my limited understanding of electronics. Please help me figure out what I'm missing.
If there is power connected:Then the top diode has 5v in the Yellow and is getting 5v pulses in the Green. I assume that since Yellow is saturated with voltage then the signal goes to the data pin instead of through the diode. The bottom diode never has a positive voltage on Black so nothing ever goes through the diode.
If the power is not connected:Yellow is an open circuit so no current flows through the top diode. No thing happens ever on the bottom diode.
Is the capacitor in the diagram "eating" the pulses when power is disconnected? Or perhaps the 1000uf capacitor in the full diagram is somehow allowing a complete circuit and draining the signal?
Other thread with full circuit diagram:
https://www.eevblog.com/forum/projects/borderlands-style-jewelry-box-research-thread/msg1858662/#msg1858662
