Mate I've told you several times on several threads to stop this, I started politely then veered into "stop being an overly pedantic twat" to hints to sod off:
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=potentiometer&_sacat=0
3rd result.
Sod off please.
Stop what, helping you? In this thread, I gave you advice on how to solve your problem by finding the part you need, since you failed on your own. It’s completely practical advice as confirmed by several other people telling you the exact same thing.
P.S. You didn’t start off politely in the other thread, you were rude to me from the start.
Edit: Looking at your posting history, I suspect you’re confusing me with someone else with whom you have had longer altercations. You and I have had very few interactions (including this one, I’ve responded to you only 3 times
ever), and in only ONE (the fuse thread) did you ask me to back off, though clearly even there you already thought we’d interacted before when we hadn’t. (Before the fuse thread, we’d only had a single exchange where you gave objectively bad advice and I objected to it briefly
because it was safety-related, you responded with a long tirade of more nonsense and a snippy “don’t overthink it”, to which told
you to be quiet. That’s it.) Hint: I’m not the only forum user with a fairly short username that starts with “t”.
Regardless, in the short time you’ve been here you’ve managed to rub a lot of people the wrong way with your abrasive, condescending attitude even when you provide bad advice, and ask questions that indicate your own lack of research and communication skills, then get mad at people who correct you or even just tell you how to solve your problem. I recognize that I, too, can be abrasive at times, even when I don’t intend to, but you’d also do well to try and be a bit more chilled.
