The BEMF on each phase goes positive and negative with respect to the virtual ground (that you're trying to make with the resistor network),
not your circuit ground, so your comparator or ADCs will never see a negative voltage (ignoring any effects of parasitics in the circuit construction).
The voltage on each phase will be pinned to ground or your bus voltage when one of the MOSFETs for the phase is on, and the BEMF will be between those two extremes when both MOSFETs are off. If the voltage on one phase tried for whatever reason to go above or below those limits, the body diodes on the FETs would start conducting and clamp the voltage.
If you probe the phase outputs to your motor while it's running with the oscilloscope ground connected to your circuit ground, you'll see something like this. Note the position of the waveform relative to the baseline.
![](https://community.st.com/sfc/servlet.shepherd/version/renditionDownload?rendition=THUMB720BY480&versionId=0683W00000AHzJg&contentId=05T3W00000aEl2Q)
