That is an expensive chip. For a bit less you could do this with two PWM outputs on a microcontroller: use one to drive a discrete boost converter at a fixed but unregulated voltage. Run an op amp off this voltage, configured as a noninverting amplifier, then put the other PWM through a low-pass filter into the op amp. Even better, skip the boost converter - just use around 24VDC as the main power supply for the programmer.
