Author Topic: What are classical jelly bean 3v3 to 5v bus tranceiver ICs called?  (Read 2731 times)
Offline king.osloTopic starter
  • Country: no
Hello,
For when I am breadboarding, what is the industry standard 3v3 - 5v tranceiver ICs called? If there is such a thing?
For I2C, SPI communication between 5V ICs to 3v3 ICs, for example.
Thank you for your time.
Kind regards,
Marius
Offline Skimask
Re: What are classical jelly bean 3v3 to 5v bus tranceiver ICs called?
« Reply #1 on: February 15, 2013, 01:00:05 am »
One example of a level translator.
https://www.sparkfun.com/products/10403
Hundreds of ways to do it...
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline dr_p
Offline Nermash
« Reply #3 on: February 15, 2013, 07:24:51 am »
I use the term "buffer". Look at 74F125 datasheet.
