thanks
![Azn ^-^](https://www.eevblog.com/forum/Smileys/default/azn.gif)
-avgrespondic: i would like to buy new, I prefer
I try to fix anything on a basic level: audio device if don't start, any household appliance, power supply... nothing difficult.
my intention is to start studying the oscilloscope starting from the basics
-Sahko123: but ds1054z is 4 channel, is not inconsiderate for me? 2 channel is not sufficient?
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
-tgzzz: thanks for warning! in general I am very attentive to safety, Every time before operating I discharge the capacitors using my special kit.
I will be well informed on the use of the probes
-rstofer: as price range I had indicated rigol 1052 or max 1202z-e (similar price..)
The siglent 1104 it's too much money for me
![Undecided :-\](https://www.eevblog.com/forum/Smileys/default/undecided.gif)
I don't make electronic plans.. I only do troubleshooting on the electronic boards
Now I only use multimeter and power supply bench, but I would like to learn to find faults also using the oscilloscope.
I would like to understand:
- for my use, is not sufficient 2 channel?
-for my budget, the bandwidth range is 50 to 200 max mhz... with 200 mhz I have many more possibilities (compared to 100mhz?)
For example the microprocessors in my amplifier work a 20mhz..
I want to start playing with the oscilloscope from the simplest things, your buying advice is very useful
Charlotte
