When first learning how to use a scope, in physics lessons at school, I found it very useful to have a real-world waveform to inspect. Clearly there is a balance between simplicity and complexity.
The advantage I had was that they were simple analogue scopes, not modern complex digitising scopes with many many controls that can be and must be understood.
in fact, starting to study the manual, these digital oscilloscopes make things of it .. it will take me time to understand every detail, I like to learn everything it does.
But for now I just need to really understand the basics, in a week I already have a better vision, but I also have huge chasms, but gradually I will improve
Yesterday i discovered another bug in our Rigol: I had setup the screen with infinite persistence to discover rare signal errors (missing pulse) and by chance some serial decoding was active (without on-screen result). Bug: No persistence at all in that configuration. I kept the scope running all night waiting for error records, to no avail. As soon as i turned off that decoder, i had the first exception record after 40 seconds. Then i used the missing pulse trigger to get a nice and clean image. That worked well..
I know that almost all oscilloscopes have bugs, from what you read ... oh well they are not too frequent
CharlotteSwiss - "I try to look at the datasheet better then. But now I have to focus more on learning the basics of the oscilloscope, then I'll focus more on the signal generator. If I take that now too, I mess up my head (already confused)"
It isn't too early to start looking at function generators. There are many out there but judging from what you have said so far I believe you would want to buy a new fairly inexpensive unit with a lot of features. One function generator worth considering is the FeelTech FY6900-60M that cost between $100 and $130USD. You can find function generators that cost 20 times more than the FY6900 but for a good hobbyist function generator, this is one to consider. If you google you can find lots of videos and written reviews on the FY6900.
If you start looking now you can get lots of recommendations, consider the various features, and when you're ready to buy, make an informed choice.
Arthur as I am made, I prefer to concentrate on one thing at a time, otherwise I'll make a mess.
I spend a lot of time choosing the things I buy, and therefore starting now I would take away my free time dedicated to the oscilloscope, which unfortunately I know very little at the moment.
The 6900, however, I have already spotted it, it is easy because I usually buy on amazon, and then it would be about the maximum expense that I could spend on a generator. But I would say that I came across a discussion here on EEV about this generator, and heavy comments were flying ..
thanks for the suggestion
+1 for it isn't too early to start looking at function generators
For a new oscilloscope user having some reasonably well understood signal to observe (sine waye, square wave, etc.) and having some control over frequency and amplitude will make learning scope operations easier to learn. With proper BNC cables and terminators (or built-in impedance controls) the generator+scope tandem will also help with understanding impedance matching, and RMS vs average vs peak measurements, etc. The FeelTech generators are probably good candidates to consider.
as I wrote above, all at the right time.
But I must admit that if I had already had it here, I could have generated precise waves, easy to study on the oscilloscope.
I will try to hurry to learn the basics of siglent at least, so then I concentrate that week to get an ideal generator for me, thanks
