Based on the size of the shunt on the meter, that’s looks to be the 10 amp version sold all over eBay. Not sure why it would go wonky at an amp, are you sure your supply could deliver the current? Sounds like ac ripple or current limiting kicking in.
Also, be careful how you supply those Chinese ammeters, they are not isolated in any way, the shunt is connected to the negative supply.
