I'm trying to come up with a quick and simple way to limit current to a nichrome burn wire. The wire resistance is about half an ohm. Depending on the wire length it looks like I need around 3-4A. The circuit is powered by a battery of my choice (most likely a small LiPo or Li-ion because that's what I have on hand).
Ideas I've looking in to so far:
The current regulating switches and protection ICs all drop the output voltage when hitting the current threshold. A lot of the other circuits I could find, such as placing a resistor between the output of a 3-terminal linear regulator require a resistor in series with the load.
I'm more or less looking for an "off the shelf" solution, however the current source ICs I could find all stopped about 1A in output. Any guidance would be greatly appreciated.
