Author Topic: waveform cliping at around 800mv/1v  (Read 2010 times)
Offline jawnuolisTopic starter
« on: August 01, 2015, 12:59:28 pm »
is there is any easy way to clip +/-13v waveforms at around +/-800mv or +/-1v? I was thinking about symmetrical  zener or tvs diode clipping but there no so small nominal diodes... any suggestions?
Offline c4757p
  • adieu
Re: waveform cliping at around 800mv/1v
« Reply #1 on: August 01, 2015, 01:33:07 pm »
Depending on the properties of the signal, a variant on the precision rectifier is probably a good choice. What kind of signal is this?
« Reply #2 on: August 01, 2015, 01:53:50 pm »
its COP coil on plug secondary ignition waveform  and when coil is turned of there is huge spikes from +/- 5v to +/- 13v and more when all useful information stays in up to 800mv region and automotive scopes not very happy about that.....
Offline langwadt
« Reply #3 on: August 01, 2015, 02:33:54 pm »
 a series resistor to limit current and a set of regular diodes to clamp pos/neg, use set of two diodes to get slightly higher voltage
« Reply #4 on: August 01, 2015, 04:35:23 pm »
do you mean this?
Offline langwadt
« Reply #5 on: August 01, 2015, 04:48:08 pm »
do you mean this?
yes, that'll clamp at roughly 0.7V
« Reply #6 on: August 01, 2015, 05:14:39 pm »
thanks will try this  :-+
Offline Marco
« Reply #7 on: August 02, 2015, 05:44:17 am »
You need a low output impedance for this to work ... if you put this in between an attenuator probe and the oscilloscope input it will not work right.
